Clbmkr1
Joined: 21 Jul 2010 Posts: 76 Location: Wind Point, Wi.
Posted: Thu May 12, 2011 1:14 am Post subject: Squealing Dump Valve |
My 1980 931 has a loud squealing sound when the dump valve releases pressure; Normal? _________________ Jim Baldwin
1980 931
2013 Lincoln MKZ
2013 Ford Escape |
Posted: Thu May 12, 2011 1:24 am Post subject: |
Nope. Seems more likely to be coming from somewhere else. . .you sure it's the recirc valve? _________________ Toofah King Bad
Posted: Thu May 12, 2011 1:33 am Post subject: |
If it is from the recirc valve, maybe it stucks halfway. I had a problem where the old gasket in the valve just melted and smered along the walls of the valve piston. Made the valve stuck open, no sound though but no boost either. Solved by buying a new gasket from porsche. _________________ 1980 924 Turbo
Clbmkr1
Posted: Thu May 12, 2011 2:10 am Post subject: |
It only squeals toward the top of the boost range, then stops as soon as you let off. It just started over the weekend. _________________ Jim Baldwin
1980 931
2013 Lincoln MKZ
2013 Ford Escape |
Posted: Fri May 27, 2011 4:51 am Post subject: |
Any chance it's a loose/leaky wastegate control line?
They're known to make a high pitched sound.. _________________ "..it's made in Germany. You know the Germans always make good stuff."
Clbmkr1
Posted: Mon May 30, 2011 11:09 pm Post subject: |
This turned out to be a loose connect at the bottom junction of the boost tube. Tightened the two bolts, now its fine.
Thanks, _________________ Jim Baldwin
1980 931
2013 Lincoln MKZ
2013 Ford Escape |
