Duncan
Joined: 04 Nov 2002 Posts: 425 Location: Delft, The Netherlands
Posted: Sat Apr 09, 2011 7:14 am Post subject: still don't understand how to jack up front of car |
I have red nearly all the jacking posts but
I still do not understand how to jack up the front of the car.
Jack point is clear: center of the cross member
But, then you will need a very low and long 'as in low over a very large part
of the jack body' jack to reach underneath the front valance. If you can find one that long and low, those very low jacks are much more expensive than quality 'regular' jacks.
The Haynes says to use a garage jack under the point where the scissor jack for tire changes attaches. Is it possible to jack up the left side, put a jack stand under the forward part of the left longitudinal box section, lower the jack and then raise the complete right hand side and put a jack stand under the right longitudinal box section?
Cheers,
Duncan _________________ 1983 NA Alpineweiss since 2001
Peugeot 205 Generation |
Posted: Sat Apr 09, 2011 7:30 am Post subject: |
Drive the car onto a couple of blocks of wood to lift the nose up around 100 - 150mm. Will give you enough clearance to use a regular trolley jack on the front cross member.
Do the same for the rear and jack up using the gearbox. Make sure you use some wood to protect the gearbox from the metal cup on the jack. _________________ 1980 931 - forged pistons, Piper cam, K27/26 3257 6.10 hybrid turbo, 951 FMIC, custom intake, Mittelmotor dizzy & cam pulley, H&S exhaust, GAZ Gold, Fuch'ed, Quaife
brealytrent
Joined: 28 Dec 2008 Posts: 414 Location: Goldsboro, NC
Posted: Sat Apr 09, 2011 7:38 am Post subject: |
For me it's always been a two person job. Someone lifts up on the front bumper so I can slide the jack (with wood block on it) underneath the cross member. Usually it only needs to be lifted a couple cm's, so it's not like you need a hulk to lift on the car.  _________________ 1977 Porsche 924 - sold
1980 Porsche 931 - sold
1984 Porsche 928 'S2' Euro - sold
2016 Ford Fiesta ST - sold
2009 Porsche Cayman |
Duncan
Posted: Sat Apr 09, 2011 7:41 am Post subject: |
Thanks gentlemen,
The standard jack I am looking at has a minimum height of 140mm.
Posted: Sat Apr 09, 2011 11:06 am Post subject: |
I usually don't bother and just do one side at a time and depending on what I want to do, I'll put a single jackstand up front or two per side.
Much easier than trying to fit the jack under the nose, etc. _________________ Stefan
BionicBalls
Joined: 05 Jan 2009 Posts: 642 Location: Charlotte, NC
Posted: Sun Apr 10, 2011 1:05 am Post subject: |
Like Carrera RSR said, you need to drive up on a couple blocks of wood then jack up. I've actually got some ramps that I use. If I don't need the wheels off thats all I need, if the wheels need to come off, it's easy to get to the jack point and throw some stands under there. _________________ 1980 924 NA
1982 931 |
Brockoli
Joined: 06 Feb 2007 Posts: 621 Location: Edmonton, Alberta, Canada
Posted: Sun Apr 10, 2011 4:53 am Post subject: |
if i need the entire car up on jack stands I jack the car up on the location that the scissor jack(the one in the trunk) uses. This point is under the car in the middle of the door section. Since the weight distribution is almost 50/50 the front and back lift up almost evenly. Once up I put jack stands under the car and lower it. Since I lowered the back end and use the weltmiester 250 springs I can barely get the jack under the car. Usually I drive up on some wood to lift the car a couple cm's. _________________ '80 924 M471,Wideband O2, Full coilover susp,23/19 sways,Bilstiens,KLA Strut Brace,Roll Bar,Test Pipe,BBS RS, Willwood BBK
'79 924 Sebring Edition(Sitting) |
staticsan
Joined: 19 Jan 2009 Posts: 450 Location: Sydney, Australia
Posted: Mon Apr 11, 2011 8:37 am Post subject: Re: still don't understand how to jack up front of car |
| Duncan wrote: | The Haynes says to use a garage jack under the point where the scissor jack for tire changes attaches. Is it possible to jack up the left side, put a jack stand under the forward part of the left longitudinal box section, lower the jack and then raise the complete right hand side and put a jack stand under the right longitudinal box section?
Yes. I have done exactly this.
Wade. |
968rz
Joined: 21 Aug 2006 Posts: 537 Location: S. E. Wisconsin
Posted: Mon Apr 11, 2011 11:28 pm Post subject: |
If I just want the front up I do the same as the manual says, but I normally just put the whole thing up. _________________ Rick
79 924 coupe Petrol Blue 3spd auto (wife's DD)
93 968 coupe Amazon Green 4spd Tip (my DD) |
924aussie
Joined: 02 Feb 2006 Posts: 1009 Location: Chinchilla Queensland Australia
Posted: Fri Aug 26, 2011 10:53 am Post subject: |
Found this , it may be of help. Bit I still want to know what is the correct way to raise the front only if you have to jack from the side
[url]
http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/468963-jacking-points-clarified.html[/url]
Alan _________________ green 924 .. 1980 rego 924PSH
1998 Mopar Neon ... sick
2003 Challenger / Montery 4WD
1995 Hyundai Scoupe ... sold
1980 Fire truck Sold |
