sputtering mystery!!! where the hell is sherlock holmes?
reilly525i
PostPosted: Sun Aug 29, 2010 5:23 am    Post subject: sputtering mystery!!! where the hell is sherlock holmes? Reply with quote
so I re timed the 80 and while driveability improved, im still having the same problem. Ill be driving and the car is doing beautifully. then 10 mins later it will start sputtering at throttle like its starving. . . vaccuum advance perhaps? CIS improperly adjusted. am I running too lean and its screwing me at running temp? any help as the car finally running great but this is keeping me from having a great driving experience. thanks.
"There are no kings inside the gates of Eden"
80 n/a 924.
76 alfa romeo spider
e34 525i.
xj6 vanden plas
vintage Sunbeam 6 speed bicycle
!tom
PostPosted: Sun Aug 29, 2010 5:57 am    Post subject: Reply with quote
Fuel filter?
78 924 NA
5-lug
tomcooper
PostPosted: Sun Aug 29, 2010 8:38 am    Post subject: Reply with quote
Sounds like a fuel pump, or fuel filter. Here is an inexpensive source for fuel pumps from ebay;
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=220558304979&viewitem=&sspagename=STRK%253AMEWAX%253AIT
I bought one for Big Red, but don't have any idea how long it will last, but it looks just like the Bosch pump without the name stamped on the side.
Casper and Big Red, both 1980 NA
Black Bart, 1990 944 S2 Cab
PostPosted: Sun Aug 29, 2010 8:50 am    Post subject: Reply with quote
Vac. leak ??
reilly525i
PostPosted: Sun Aug 29, 2010 9:55 am    Post subject: Reply with quote
Joes924Racer wrote:
Vac. leak ??
thats what Im thinking. . . i tried something a few minutes ago. . . i let you guys know tommorow if it worked or not. . .
80 n/a 924.
e34 525i.
xj6 vanden plas
reilly525i
PostPosted: Tue Aug 31, 2010 12:25 am    Post subject: Reply with quote
I got it!!! a lead on the temp switch was off. . . I put it back on and inside of 5 minutes the sputtering was gone. . . wierd right?
80 n/a 924.
e34 525i.
xj6 vanden plas
PostPosted: Tue Aug 31, 2010 11:07 am    Post subject: Reply with quote
Tell us more about this temp switch.
reilly525i
PostPosted: Tue Aug 31, 2010 11:17 am    Post subject: Reply with quote
ok. I installed a temp guage about 2 weeks ago and while installing the sensor I must have knocked the lead off the stock sensor. I noticed the sputtering had started lightly after the install and gradually grew worse. upon re affixing the lead the sputtering started to weaken and after a day is almost completely gone. . . wierd right?
80 n/a 924.
e34 525i.
xj6 vanden plas
