80-924
Guest
PostPosted: Sat Jun 09, 2001 12:46 pm    Post subject: Reply with quote
Email: patrick_mchugh_pgh@yahoo.com
Date: 09 Jun 2001
Time: 12:46:18
OK - car will start as I'm getting fuel through the cold start system - but there is no fuel through the injectors into the cylinders.
I took the injector lines off and there is no fuel coming out of the fuel distributor to the lines.
What should I do next?
Take off the top of the fuel distributor to look for it beng blocked or ????
Thanks in advance for any help!!!!!
Guest
PostPosted: Sat Jun 09, 2001 1:17 pm    Post subject: Reply with quote
Email: l_porsche@hotmail.com
Date: 09 Jun 2001
Time: 13:17:33
it sounds liek the fuel distributor is jacked, can you get a used one somewhere? because you will probably need one...
First though, Did you pull the sensor plate up while having the fuel pump on by jumping the relay, to see if any fuel comes out the lines or injectors.
Guest
PostPosted: Sat Jun 09, 2001 8:51 pm    Post subject: Reply with quote
Email: jod3511@home.com
Date: 09 Jun 2001
Time: 20:51:40
I have a fuel dist. I know is good cause its worken now ... name your price or $100.00
will trade for a good clutch
