Email: sean@kdsi.net
Date: 07 Jun 2001
Time: 19:36:47I just bought my first Porsche yesterday. It is a junker, but runs good. The guy was driving and the hood came unlatched and flew up. The hood is bent up badly, but probally can be hammered out to work until I begin the new paint job and just buy a new hood. The windshield is also craked, but I am having it replaced this week. Other then that the car has taken and beating and is still runnin' strong. The interior is in horrible condition, so thats where I'm going to start restoring it. The front seats are being a bitch. First off, I can't slide them up at all, so its a real pain to push in the clutch pedal. Sencondly, the backs will not stay up either. I know nothing about these cars, or what can be done with them. What would you reccomend? Getting a new pair of seats? Ripping mine apart and restoring them? Does anyone sell re-covering kits for the seats?
I am also pretty sure the throw-out bearing is going out on the car. What would you reccomend, just rebuilding the clutch completely or just replace the bearing?
When I go out in the morning to start it up, it does start right up. But if I stall it, or shut it off and try to start it up again soon, it doesn't like to start. If I push the gas pedal to the floor, it starts right up. Any ideas on what is wrong here?
Shift points, what are they? I guess that pretty much says it all. What RPM is good for launching and shifting. (BTW, this is my first manual tranny car, so I'm not to experienced, thats why I ask)
OD and trip meter have quit, so I'm a little concerned how far I can go on a tank of gas. What kinda gas milage can I expect with this car. (5 spd. 81 924, non-turbo)
On the center console there are 3 little rocker switchs, and an empty hole for another one. What are they? All the lettering have been rubbed off, and I haven't a clue as to what they do.
There is a black toggle switch on the drivers side of the center console, just above the heat/ac controles. It seems to controle a fan under a vent in the rear center of the battery compartment up front. What is this for?
On the rear hatch, the dummy who owned it before me drilled out the lock cylinder. From the inside I can turn the little plate that is connected to each latch, but the driver side latch doesn't release. I took the little bottem side cover off, and manually tried to push the release and nothing. Where can I get a new setup, preferably both latches and the lock cylinder?
Last question for the day. Does anyone sell aftermarket interior products for this car? Like digital guages, extra guages, things like that? Where do you guys buy your aftermarket and replacement parts?
Thanks!
