Rich H
Posted: Wed Apr 07, 2010 6:19 pm Post subject: Stupid 924 question amnesty |
Shamelessly copied from another forum, what do we think about a stupid question amnesty for all those daft questions you were afraid to ask?
Rules are simple - must be at least vaguely relevant to the 924 and no one is to be ridiculed on here. If you have nothing constructive to add - don't.
Rich _________________ 1994 Lotus Esprit S4 - Work in progress...
Posted: Wed Apr 07, 2010 6:59 pm Post subject: |
Should i cut off the thick green wire that goes to the silver ignition box above my left wheel, or leave it there and pretend megasquirt will need it  _________________ 1979 NA
my Porsches Arse!!! |
Rich H
Posted: Wed Apr 07, 2010 7:52 pm Post subject: |
Thick green is the VR sensor in the Dizzy MS will not need it if you are using a crank trigger.
It is however co-ax so would make a good wire to use for your crank sender to reduce noise, rip it out and use it.
I ripped it out of my old car on MS. _________________ 1994 Lotus Esprit S4 - Work in progress...
Posted: Wed Apr 07, 2010 7:55 pm Post subject: |
ok, what did you do with the other wires that run to the little silver box?...cut at the wire harness junction near the firewall?
mmm i like the stupid question idea  _________________ 1979 NA
Rich H
Posted: Wed Apr 07, 2010 8:12 pm Post subject: |
http://www.pelicanparts.com/944/electrical/924_78_1_1.jpg
For a 78 car apparently.
Looks like:
Ground
+12
Tach/Coil
Later cars might have different connections. The box just acts as the 'points' for the dizzy so it's not that special/complex.
Remove/rewire as appropriate. I'd not cut them but pull them out form the main loom in the car. _________________ 1994 Lotus Esprit S4 - Work in progress...
9XX Girl!
Joined: 20 Sep 2009 Posts: 1617 Location: Cornish Riviera SW England
Posted: Thu Apr 08, 2010 6:33 am Post subject: |
ok here is my contribution.
Is there a tool for adjusting the washer jets for the headlights. I need something that can do the job without marking them?
Also, are the metal headlight covers the same shape for the 924 and 951?
my 924 ones never fit the holes in my 951 body work (wings / fiberglass nose panel / bumper) that perfectly. They will do (fit flush etc) but they do not have completely parallel shut lines all the way around the covers. the lines along the front taper slightly.
And, i have some sort of electrical in line temp sensor in the narrow heater hose by the bulkhead / WUR / coil area. It is not on the wiring diagrams for the year of my car and on the parts list it is listed as a vacuum switch not an electrical switch Never tried disconnecting it though. _________________ 924 (84) N/A 2 ltr - 5 Speed - BLACK - Project (looking for 200BHP, any ideas!)
924 (81) N/A 2 ltr - 3 Speed Auto - SURINAM RED (Metallic) - Near Original Spec (sticking with originality)
BOTH ON THE ROAD, BOTH USED EVERY-OTHER DAY |
DOCO
Joined: 04 Aug 2006 Posts: 1111 Location: Keswick Ontario Canada
Posted: Thu Apr 08, 2010 7:23 am Post subject: |
your right its a engine temp.sensor.its to tell the computer what temp the eng. is to adjust vacuum to the distributor vacuum advance _________________ Doco "where am i going and why am i in this handbasket"author unknown
79 924 N/A "Webster"
_______
/______\
[+]___[+]
\0 924 0/
[__]..[__]
"WEBB STR" |
9XX Girl!
Posted: Thu Apr 08, 2010 7:30 am Post subject: |
| DOCO wrote: | | your right its a engine temp.sensor.its to tell the computer what temp the eng. is to adjust vacuum to the distributor vacuum advance |
Ok, firstly my car has no computer as it is a 1984 924N/A and secondly the advance retard is done via a vac line that goes directly between the dizzy and the TB.
The parts list says it should be a Vac Temp Sensor but it isn't. Its electrical
Also the parts list does not say where it should connect _________________ 924 (84) N/A 2 ltr - 5 Speed - BLACK - Project (looking for 200BHP, any ideas!)
Rich H
Posted: Thu Apr 08, 2010 7:33 am Post subject: |
| 9XX Girl! wrote: | ok here is my contribution.
Is there a tool for adjusting the washer jets for the headlights. I need something that can do the job without marking them? |
They are very stiff - I believe there was a tool but I used a screwdriver that fitted in the slot, not great but it worked...
| Quote: |
my 924 ones never fit the holes in my 951 body work (wings / fiberglass nose panel / bumper) that perfectly. They will do (fit flush etc) but they do not have completely parallel shut lines all the way around the covers. the lines along the front taper slightly. |
No idea...
| Quote: | And, i have some sort of electrical in line temp sensor in the narrow heater hose by the bulkhead / WUR / coil area. It is not on the wiring diagrams for the year of my car and on the parts list it is listed as a vacuum switch not an electrical switch Never tried disconnecting it though. |
It's a temp switch for the extra solenoid valve on the CIS IIRC, it to do with cold starting control pressures. The solenoid is the vertical cylinder bolted to the side of the fuel dizzy. _________________ 1994 Lotus Esprit S4 - Work in progress...
9XX Girl!
Posted: Thu Apr 08, 2010 7:46 am Post subject: |
| Rich H wrote: | | They are very stiff - I believe there was a tool but I used a screwdriver that fitted in the slot, not great but it worked... |
Yer.. i have moved one like this but it places a bur on the edge of the plastic slot.
| Rich H wrote: | | It's a temp switch for the extra solenoid valve on the CIS IIRC, it to do with cold starting control pressures. The solenoid is the vertical cylinder bolted to the side of the fuel dizzy. |
Thanks, that makes scene. Never had a cold start prob so have I never been there.
Anyway, thats all the stupid stuff i can think of for now (i think). other than why did Porsche design the electrics so that the brakelights work when you press the pedal without the ignition on, but the horn does not??????  _________________ 924 (84) N/A 2 ltr - 5 Speed - BLACK - Project (looking for 200BHP, any ideas!)
staticsan
Joined: 19 Jan 2009 Posts: 450 Location: Sydney, Australia
Posted: Thu Apr 08, 2010 8:56 am Post subject: I got one. |
If I read the wiring diagram right, when the ignition and the lights are off, the blinker stalk will turn on the left or right front parking lights. But on my car, either direction turns on both parking lights. Is this correct?
No, I don't have an owner's manual. The PO didn't have it.
Wade. |
9XX Girl!
Posted: Thu Apr 08, 2010 10:05 am Post subject: Re: I got one. |
| staticsan wrote: | | If I read the wiring diagram right, when the ignition and the lights are off, the blinker stalk will turn on the left or right front parking lights. But on my car, either direction turns on both parking lights. Is this correct? |
No Wade you have a fault, in your blinker stalk i guess. _________________ 924 (84) N/A 2 ltr - 5 Speed - BLACK - Project (looking for 200BHP, any ideas!)
924guy
Posted: Thu Apr 08, 2010 10:24 am Post subject: |
| Quote: | Also, are the metal headlight covers the same shape for the 924 and 951?
No, they have slightly different dimensions, not far enough for them not to work, but enough to bug you if stare at them for a minute... _________________ Eric
78 924
82 931 SE "smokey"
99' VehiCross
Y2K Honda Insight
Performance by Pasha |
Posted: Thu Apr 08, 2010 10:52 am Post subject: |
Wade, try swapping blinker relay. _________________ Toofah King Bad
Posted: Thu Apr 08, 2010 11:08 am Post subject: |
I use a straight pin to adjust the washer nozzles. Just insert it and use it lever the nozzle into position. _________________ White 87 924S "Ghost"
