Email: polaris7@softhome.net
Date: 05 Jun 2001
Time: 11:59:08I had the normal CIS system in the '79 I have, I was having every possible problem with it:
Cold Start problem (neither grounding or hotwiring the valve with a switch helped)
non-equal flow from injectors
bad idle and running
I came upon a weber conversion on Ebay and won the auction for $320+shipping (I had to get a lo-pressure fuel pump for $40 and misc fuel plumbing parts in addition), took about 5 hours total to install, and all my problems were solved. The choke was not required, but I installed it anyway, it starts up on the first crank every time and definetly revs much faster (I don't know about power increase because it was running like poo when I got the car, so I have no comparison). I am currently porting a head to put in and am going to get a cam and also working on a supercharger design to go with the Webers.
Alex Roy
White '79 N/A, Webers, and more to come.
