gcomenale Guest
Posted: Mon Aug 05, 2002 2:35 am Post subject: |
I'm thinking about replacing my 914 autocrosser with an '88 924s. Looking for opinions... Does anyone have experience with the following setup:
ENGINE: Autothority chip, K&N, larger throttle body, header, exhaust, ported head.
SUSP: corner balancing, Koni yellows, strut brace, negative camber, stiffer coils and torsion bars, R compound tires.
I don't expect the car to handle quite as well as my 914, but the extra HP sure does generate more smiles.
thanks |
Joined: 29 Jul 2001 Posts: 9080 Location: Royal Oak, MI, USA
Posted: Mon Aug 05, 2002 10:10 pm Post subject: |
The car should be able to equal the 914 in handling, with the exception of being a little heavier (I believe) and not rotating quite as quickly. That might hurt you a little in autox, due to the transient nature...
Anyway, the suspension work doesn't seem like an issue, just have to get it sorted out... might want stiffer bushings too, depending on your preference.
Lizard Guest
Posted: Wed Aug 14, 2002 5:36 am Post subject: |
| go with 1100lb springs and polyurathane bushings all round |
924 turbo Guest
Posted: Wed Aug 14, 2002 5:59 pm Post subject: |
I say 1200 pound springs. 1100 pound springs are for grandmas.
Posted: Wed Aug 14, 2002 11:13 pm Post subject: |
As always, very helpful advice from the peanut gallery.
-nick Guest
Posted: Thu Aug 15, 2002 2:31 am Post subject: |
you're in vernon? i'm not sure exactly where that is, but check out an event at Ft Devens with the NER PCA. there are lots of 944's that show up and you can ask them what they use for suspension changes. everyone has a different opinion. is this going to be a dedicated a/x'er? if so then go crazy with the stiffest setup you can find as long as you keep the front/rear spring rates roughly equal (most like a little more spring in the rear).
ps- you realize that the engine mods you listed will put you in a modified class where you'll get spanked?
-nick |
Joes924 Guest
Posted: Sat Aug 31, 2002 4:36 pm Post subject: |
Id like to have spring in my rear..
