kris Guest
Posted: Wed Aug 21, 2002 5:52 am Post subject: |
Does anyone know what terminals I need to hook onto to wire up my remote starter (its a 2 terminal hand control unit)?.. Its probably simple to figure out Im sure, but I dont want to burn up my starter due to simple ignorance....
John H Guest
Posted: Wed Aug 21, 2002 10:51 am Post subject: |
| On the 931 starter there are two wires to the starter - one big fat wire - this is the main battery feed and a much smaller wire. If you connect one end of your switch to the smaller terminal (spanner size about 8mm) and then run the other side of you switch to the positive termnial of your battery. When you flick the switch it will energise the solenoid and the starter will work. |
numbers Guest
Posted: Sat Aug 24, 2002 3:56 am Post subject: |
| John's got it. I have a remote start switch mounted in the engine compartment. Great for troubleshooting. |
