lost oil pressure , 77 924
PostPosted: Thu Mar 09, 2000 3:16 pm    Post subject: Reply with quote
Email: gjoe@cbpu.com
Date: 09 Mar 2000
Time: 16:16:44
parked over winter and on start up oil pressure drops to zero within 2 min. . ck. bypass and new filter.
PostPosted: Thu Mar 09, 2000 4:55 pm    Post subject: Reply with quote
Email:
Date: 09 Mar 2000
Time: 17:55:09
Check the plastic oil tube elbow on the cam. Pull the cover to get at it. It may have split or shattered. Second make sure your sender is operating correctly, clean all the wires and check for a good ground, the same on the gauge. The best thing is to add a mechanical gauge either on engine (the cool thing to do) or in car. This will give you an accurate reading 99% of the time, where the elctrical is prone to alot of gremlins. Let me know what you find. Two questions though, what was the presure at first start compared to last year, and could the oil be contaminated with gas. (thined out)
PostPosted: Thu Mar 09, 2000 8:10 pm    Post subject: Reply with quote
Email: webmeister@924.org
Date: 09 Mar 2000
Time: 21:10:16
I'm with Bob. What is the initial oil pressure before it drops to zero?
John
