| Who wants an aluminium cam oil tube elbow? |
| Not me |
4% |
[ 2 ] |
| I want one |
46% |
[ 19 ] |
| I want 2 or more |
41% |
[ 17 ] |
| I may get one if they are cheaper than the genuine ones |
7% |
[ 3 ] |
| I may get one if they are cheaper than the genuine ones but only after I`ve killed my motor due to the old one failing |
0% |
[ 0 ] |
| Total Votes : 41 |
Posted: Wed Nov 21, 2007 10:02 am Post subject: Brass cam oil tube adapter - NOW a reality! |
How many 924 owners would be keen to replace the POS plastic part with a direct replacement reliable aluminium or brass one if they were available at reasonable cost?
Roger
steeny
Joined: 24 Nov 2005 Posts: 319 Location: Brisbane, Australia
Posted: Wed Nov 21, 2007 11:05 am Post subject: |
yep, i'd be up for that
either ally or brass. not fussed either way.... _________________ 1978 924 N/A
she's gone..... |
Min
Posted: Wed Nov 21, 2007 11:06 am Post subject: |
All depends on what 'reasonable cost' is. I'm interested, but I've also considered just lathing one out myself.
PwrGTOGuy
Joined: 23 Jun 2007 Posts: 194 Location: Middletown, PA
Posted: Wed Nov 21, 2007 11:55 am Post subject: |
I'd be down for one, especially since everything is out, brand new, and easy to replace now.  |
968rz
Joined: 21 Aug 2006 Posts: 537 Location: S. E. Wisconsin
Posted: Wed Nov 21, 2007 12:06 pm Post subject: |
I'd go for two (just incase) but like everyone else; as long as they aren't crazy $$$. Last one i bought was about $2us at a repair shop in Mayland. _________________ Rick
79 924 coupe Petrol Blue 3spd auto (wife's DD)
93 968 coupe Amazon Green 4spd Tip (my DD) |
Posted: Wed Nov 21, 2007 12:32 pm Post subject: |
Considered ally or brass too and I`m not fussed either way either. Only ally is cheaper and easier to machine.
Figured "reasonable" is <$20 since this is a 924 part and is $16 at Pelican for the plastic one or probably a bit more at the dealer.
http://www.pelicanparts.com/cgi-bin/PartsLookup/search.cgi?command=show_page&Catalog_Name=924_USA_80_85_KATALOG&Illustration=104-00&Line_Item=19
Min wrote:
| Quote: | | I'm interested, but I've also considered just lathing one out myself. |
Yea, me too Min.
If you are interested in making some I am happy to buy one from you. We both know that realistically to make one from start to finish will involve many hours work, measuring, design, sourcing materials, tools, set up, turning, drilling, deburring, cleaning, testing, etc..... So personally dont wish to make more than one for myself. If there is much demand it may be worth having a machine shop do a manual run of 10 or 20. With economies of scale it may also be worthwhile having a CNC shop spit out say a minimum run of 50-100. Obviously then the price per unit will fall dramatically.
Hope you all can see where I`m coming from. This is why I am trying to gauge the interest and demand before I waste much time or money.
Roger |
Posted: Wed Nov 21, 2007 2:44 pm Post subject: |
yeah we should have about 50 made. . .might irritate some "swap meet hoarders" tho
sign me up for whatever investment necessary _________________ Toofah King Bad
steeny
Posted: Wed Nov 21, 2007 2:46 pm Post subject: |
If i had access to a lathe, i would have made one of these ages ago.
I honestly cant see it taking that much time. just drill two holes in a bit of square rod, and then turn one side off for the inlet.
it doesn't have to be pretty, or look exactly like the plastic one, just functional. at least, thats how i see it, _________________ 1978 924 N/A
she's gone..... |
gohim
Posted: Wed Nov 21, 2007 4:11 pm Post subject: |
I think making a good part would take more than a few minutes of thought, and a little more work than one might think.
Brass would not be good because vibration would crack it.
O-ring seals on each end would be required to seal, since you can't duplicate the locking rings on the plastic part. Viton seals would be best, and that means grooving the oil delivery tube end internally, and grooves on the exposed end on the cylinder head side.
O-rings would also allow the elimination of metal to metal contact, and frictional wear of the parts in contact, to give the part a long life. |
Posted: Wed Nov 21, 2007 4:44 pm Post subject: |
| RC wrote: | | this is a 924 part and is $16 at Pelican |
Did you confirm availability on this? _________________ Toofah King Bad
Tiny
Posted: Wed Nov 21, 2007 9:56 pm Post subject: |
Count me in
I can't find the wee plastic thingies over here in the UK and mine is cracked but still functional.
thanks,
Tiny _________________ *****1981 - 924 - Auto - London, UK****** |
Posted: Wed Nov 21, 2007 11:00 pm Post subject: |
Essentially agree with your comments gohim.
As far as availability goes the dealer DIDNT say they were not available, but he may not have bothered to check either. At the time enquired about numerous parts and the reply was that there is a weeks delay as some had to come from Germany, but the elbow was not specifically mentioned. I know many people in different countries seem to be unable to get them, as Tiny mentioned.
Roger |
Posted: Thu Nov 22, 2007 1:34 am Post subject: |
Two for me please, If it will fit tightly and not leak.
I guess more swedish 924 owners will order at the same time since this part isnt even available from Porsche.
How will you make them, or will a workshop make them for you ? _________________ 1980 924 Turbo
Posted: Thu Nov 22, 2007 2:41 am Post subject: |
These are NA, according to PCNA. Pelican also reports a goose egg. _________________ Toofah King Bad
Min
Posted: Thu Nov 22, 2007 4:18 am Post subject: |
| RC wrote: | | Figured "reasonable" is <$20 since this is a 924 part and is $16 at Pelican for the plastic one or probably a bit more at the dealer. |
At that kind of price, put me down for 4 of them.
| RC wrote: | | We both know that realistically to make one from start to finish will involve many hours work, measuring, design, sourcing materials, tools, set up, turning, drilling, deburring, cleaning, testing, etc..... So personally dont wish to make more than one for myself. |
Yep, definately not trival. And testing could get messy. Especially if something fails.
