Where is the PCV/Air Cleaner Line? (Early 924)
Pca944
PostPosted: Wed Sep 05, 2007 7:03 am    Post subject: Where is the PCV/Air Cleaner Line? (Early 924) Reply with quote
I'm trying to find the PCV/Air Cleaner Line to finish the connection from the charcoal canister. Where can I find it?
1986 944 | 1978 924 (FS) | 1982 931 | 1980 931
Pca944
PostPosted: Thu Sep 06, 2007 3:32 am    Post subject: Reply with quote
Even a photo of a 924 engine bay with exhaust recirculation system might help.
PostPosted: Thu Sep 06, 2007 3:54 am    Post subject: Reply with quote
I'm not an NA'er, so can't give specific details, but that line just goes to the intake however you can get it there - either to a port on the air-cleaner box or to part of the intake plumbing halfway between the fuel distributor and the throttle body. Check those areas - if you find a similarly sized line already attached at either, that would be the line from the crankcase breather.
The Haynes shows your line as "10 Vent line" on pg.102.
Pca944
PostPosted: Fri Sep 07, 2007 3:10 am    Post subject: Reply with quote
Thanks. I think I found the connection. Now I just need to find a replacement hose.
PostPosted: Fri Sep 07, 2007 4:35 am    Post subject: Reply with quote
You'll want an oil/fuel resistant hose like EEC/PCV/Fuel line from any local auto parts store.
If you feel you need to replace with the OE-looking outer-cloth-braided stuff, I posted a link to a place that sells it in here - http://www.924board.org/viewtopic.php?t=22595
