Wastegate mods
rdjohnston50
PostPosted: Fri Jul 20, 2007 11:42 pm    Post subject: Wastegate mods Reply with quote
I've read about the wastegate mod which uses a different spring and diaphram to increase boot up to 8 or so. Whats a source for these parts?
924guy
PostPosted: Sat Jul 21, 2007 12:10 am    Post subject: Reply with quote
diaphragm is the same, spring update is a 930 unit, from .7 bar to 1.2 bar . i stuck in a 1.1 bar spring , but without other upgrades like an Intercooler or water injection, its pretty much over kill as i have to keep the boost dialed down. i can easily hit the boost cutoff at 25 psi, i tried to keep it below 17psi. since stock boost is 7psi... its a rush. after the rebuild i will probably keep it at a much more conservative 10-12 psi. i wasnt to worried about blowing anything up before, needed a rebuild anyhow. on a fresh engine ill just have to learn to be a bit more responsible in my boost usage
I got my parts from Andial, however they may be more difficult to source, these items are getting harder and harder to find.
Eric
78 924
82 931 SE "smokey"
99' VehiCross
Y2K Honda Insight
Performance by Pasha
rdjohnston50
PostPosted: Sat Jul 21, 2007 1:46 am    Post subject: wastegate mod Reply with quote
Thanks for the info. I was thinking of limiting the mod to a stiffer srping. I'll check out Andial though.
PostPosted: Sat Jul 21, 2007 8:52 am    Post subject: Reply with quote
I have a Weltmeister 1.0 Bar spring for sale. Make me an offer.
rdjohnston50
PostPosted: Sat Jul 21, 2007 11:34 am    Post subject: wastegate mod Reply with quote
back to 924 guy - so if I check out a diaphragm and 1.0 spring for a 930 wastegate, they will fit the wastegate in my 82-924? I see lots of available parts for the 930.
PostPosted: Sat Jul 21, 2007 1:39 pm    Post subject: Reply with quote
It's the same wastegate as a 930, but a 1 bar spring is too much for a stock 931.
jazz guy
PostPosted: Sat Jul 21, 2007 4:01 pm    Post subject: Reply with quote
Paul is right. Without a IC or water injection, 1 bar is definitely pushing it. On hot days, it is doubtful that you'll be able run boost that high without the risk of engine damage.
You might consider a variable boost controller, then you have some control over boost limit. There are some cost effective options for you. Take a look at the following thread if you are interested, it talks about several options.
http://www.924board.org/viewtopic.php?t=5373&highlight=boost+controller
Cheers, Brian
924guy
PostPosted: Sat Jul 21, 2007 11:23 pm    Post subject: Re: wastegate mod Reply with quote
short answer, yes. i think the gaskets are 930 p/n's as well, but verify.
but again, get a good quality BC if your going to run a higher spring rate....
Eric
78 924
82 931 SE "smokey"
99' VehiCross
Y2K Honda Insight
924guy
PostPosted: Sun Jul 22, 2007 10:15 am    Post subject: Reply with quote
some pics i had from the last time i messed with this stuff..
the white spring is the 1.1 bar, vs the original.
Eric
78 924
82 931 SE "smokey"
99' VehiCross
Y2K Honda Insight
