porsche.racer
Joined: 20 Jun 2006 Posts: 106 Location: california, US
Posted: Tue Jun 20, 2006 1:38 pm Post subject: hi all, nebee here!! |
I wonder if anybody can help me with fuel/air mixture co2 set up? I just cant seem to get my car running well. Pretty good when its hot, but when its could its bad. What about timing, what should a 1980 924 t be set at.------ ???
well not sure if this is enogh info......so if you have questions, about my set up please ask.
mike _________________ 1987 911 3.6L Carrera with LSD
1986 944 Turbo (Track)
1972 911 3.0L Turbo Look
1988 944
100's of good used parts MUST GO
Check me out on EBAY I.D. porsche.racer |
allen
Posted: Tue Jun 20, 2006 3:00 pm Post subject: |
1980 Turbo per Haynes page 124
Ignition timing 20 d BTDC at 2000 +/- 50 rpm (all models except UK)
UK - 9 d BTDC at 950 rpm 25 d BTDC at 2000 rpm _________________ EARLY 77 924 N/A |
Posted: Wed Jun 21, 2006 11:34 am Post subject: |
Have you checked all the usual suspects? _________________ White 87 924S "Ghost"
porsche.racer
Posted: Wed Jun 28, 2006 12:48 am Post subject: check usual suspects |
yes the car is in excellent order, has been stripped and re-assembled. Ok, so the car will run super when hot but on start up its one ugly runner, rough rough rough!! Put foot on gas and it bogs, chokes untill rpm hits about 3500 and then its not bad. It will do this until the car is running hot after about 10 mins or so. How do i test co2 and mixture. Is there a setting im missing.
I adjust the timing, the little co2 screw in the airflow meter (from the top) and the idle control on the tbody. is there something im missing?
again this is an 80 931
thanks _________________ 1987 911 3.6L Carrera with LSD
1988 944
Posted: Wed Jun 28, 2006 1:06 am Post subject: |
Quite likely the Warm-up Regulator isn't getting powered. Check to make sure it's getting +12VDC when the ignition's on. _________________ Vaughan Scott
porsche.racer
Posted: Wed Aug 09, 2006 12:47 am Post subject: |
all sorted!!! it was my cat after all _________________ 1987 911 3.6L Carrera with LSD
1988 944
