ReicheBrown
Joined: 26 Jul 2005 Posts: 21 Location: Stroudsburg, PA
Posted: Wed Jul 27, 2005 12:07 pm Post subject: Electical problems |
82 924 Wiiper fuse blowws when ever i try to use the fluid (pull back on the lever) I was wondering why my car came with a box of fuses in the ash tray, but they came in handy
Any thoughts |
Posted: Wed Jul 27, 2005 2:08 pm Post subject: |
Unplug the positive wire from the pump and using a meter, check to see if the pump or the positive lead is shorted to ground.
Or if you don't have a meter, pull the positive wire at the pump, put in a new fuse and pull the lever. If the fuse blows the wiring or switch is shorted, if the fuse doesn't blow the pump is shorted. _________________ White 87 924S "Ghost"
