rebelgtp
Posted: Sun Jul 03, 2005 3:07 am Post subject: looking at getting a 931 |
well i'd like to say "hi" as i'm new to the boards. i was actually directed this way by some of the guys over at pelican parts for my questions on a 931.
i recently found one here localy (that i'm hoping to go test drive and check out this weekend) for a $1600. its a 1979 4 lug car, from what i have seen so far very clean car, black and silver paint no body damage, black leather interior in good shape and a claimed 80 some thousand original miles.
anyway i actually use to drive a 944 so i know a few things to look out for but since this is an ealier car and completely differant under the skin what should i look for? i'm going to see if i can get any records on the car or if it was taken to any of the local dealers i know and see what they have to say about the car.
thanks in advance for any help. |
Posted: Mon Jul 04, 2005 2:31 pm Post subject: |
Mostly the usual car check-out stuff - look for good accelleration and sure braking without odd noises. Sounds that indicate things are working properly on a 924 turbo are a fairly loud click each time you let off the throttle and the turbo whining sound on accelleration. The wastegate and turbo generally need service at 5-10 year intervals, so try to find when they were last rebuilt/replaced. The engine is an interferance design, so you have to keep on top of that and change it [the timing belt] approx. every 2-3 years. It's not as big a deal to do as on a 944 and requires only about $25 in parts (the belt + tensioning pulley). _________________ "..it's made in Germany. You know the Germans always make good stuff."
Khal
Posted: Tue Jul 12, 2005 9:02 am Post subject: |
| Smoothie wrote: | | Sounds that indicate things are working properly on a 924 turbo are a fairly loud click each time you let off the throttle |
No way! I thought there was something wrong with mine! I always wondered what that click was... _________________ '80 924 Turbo |
Posted: Tue Jul 12, 2005 12:43 pm Post subject: |
Yes that click is a good one. If you don't hear it, something's wrong. It's the sound made by the turbos' bypass valve - when you let off the throttle, vacuum rises, shoots down that big vacuum line from intake runner 1 to the bypass valve and pulls it open - "click". _________________ "..it's made in Germany. You know the Germans always make good stuff."
JamesWilson
Joined: 10 Jun 2005 Posts: 132 Location: San Diego, CA
Posted: Thu Jul 21, 2005 2:18 am Post subject: |
Dangit, no clicky on mine...just a big BOV "woosh" with the K&N intake system on there.
-JW _________________ '82 924 Turbo (not stock) - soon returning home?
www.AffordableRacingData.com |
Kenodog
Posted: Sat Jul 23, 2005 10:04 am Post subject: |
I can't recall hearing that either.The turbo was profesionally built a year ago,think I should get that looked at ? _________________ 1979 Euro 931, Olive
1981 931, Sabine
1996 Ford E-350 ex-FedEx Van
2014 Mazda CX-5 (Kinderwagon)
2019 KTM 790 Adventure
2024 KLX300
2024 KLX140 |
J1NX3D
Joined: 06 Feb 2003 Posts: 1333 Location: New Zealand
Posted: Sat Jul 23, 2005 10:54 am Post subject: |
clicks on mine! gd to know im not going crazy :O _________________ '86 944 |
skemcin
Joined: 02 Sep 2003 Posts: 1284 Location: Plainfield, IL
Posted: Sat Jul 23, 2005 12:32 pm Post subject: Re: looking at getting a 931 |
| rebelgtp wrote: | well i'd like to say "hi" as i'm new to the boards. i was actually directed this way by some of the guys over at pelican parts for my questions on a 931.
thanks in advance for any help. | help this guy out . . . http://www.924board.org/viewtopic.php?p=126021
if you wanna spend $1600, help a fellow board member out and get two cars for that price.
. . . and you're not that far from him (just a thought).
 _________________ 924.org (no time to complete)
9249206346 - 89k – new shifter bushings, belts, running well.
9249206347 - 8k – waiting its resurrection, no power at the fuel pump and fuse #7 blows w/power |
Posted: Sat Jul 23, 2005 4:28 pm Post subject: |
| Kenodog wrote: | | I can't recall hearing that either.The turbo was profesionally built a year ago,think I should get that looked at ? |
A recording of the popoff valve - with mics placed below* the pov, operating the throttle from the engine compartment.. It clicks on both opening and closing the throttle (287 KB) -
http://www.geocities.com/smoothies931sounds/PopOffValveClick18sec-48kHz16bitStereo.mp3
* - You should hear it just as well from above the engine. _________________ "..it's made in Germany. You know the Germans always make good stuff."
Wolf1
Joined: 10 Feb 2003 Posts: 109 Location: Idaho Falls ID
Posted: Mon Oct 03, 2005 4:37 am Post subject: |
Yep, mine clicks. You can hear it very clearly from the drivers seat if the door or window is open. _________________ 88 951 stone gray
80 931 Red and surgically enhanced
72 914 (old toy) $old
2 1/2 924's for spares.. |
numbbers
Joined: 05 Nov 2002 Posts: 1910 Location: Highlands Ranch, Colorado
Posted: Mon Oct 03, 2005 9:17 am Post subject: |
Well, I have had three different turbo's in mine over the years, and have never heard a click. _________________ 1980 924 Turbo |
WEASEL149
Posted: Mon Oct 03, 2005 9:31 am Post subject: |
If it's the standard K26 with the recirculating bypass valve then the easiest way to hear the clack/click is to just pop the bonnet while the car is idling, then rev the car on and off by hand at the throttle body. You should be able to hear the valve opening and closing, making the 'clacking' or 'clicking' noise. _________________ 1979 UK 932 |
Dans931
Posted: Thu Jan 26, 2006 3:35 pm Post subject: click |
I have always heard the click. After 185,000 miles the head gasket blew. I am sure the turbo is original as I have all the service records. Mobil one must be good. I really miss my 931.
Daniel
82 931 (retired) |
