Exhaust Backfiring/Popping
tj924
PostPosted: Wed Jul 20, 2005 12:33 am    Post subject: Exhaust Backfiring/Popping Reply with quote
I am now getting these little backfiring/popping sounds from the exhaust when I let off the accelerator. This only started a week or so ago when the big rubber boot that connects over the air metering plate popped off the plastic tube that leads to the next rubber boot & caused the car to run really crappy (drove it home about 35 km like that & discovered the problem the next morning). That has now been fixed (rubber boot & plastic tube both pulled off completely, inspected for cracks & reinstalled). Car is running fine (apart from a cold start problem & this backfiring), idles fine, accelerates fine & has new spark plug leads, water pump & a few new vacuum leads as at last weekend (replacing them as time permits).
Any suggestions? Hole in the exhaust or perhaps now running too lean for some reason?
TJ
Silver '82 924 NA 5-Speed Manual
dpw928
PostPosted: Wed Jul 20, 2005 10:19 am    Post subject: Reply with quote
May want to check the advance and retard (if equipped) vacuum lines that run to the distributor. If loose or reversed your retard timing would cause the popping. Also, has the exhaust been modified or blown out? My 928 started the same thing when I installed a rear muffler bypass.
Dennis
81 931 5 sp
78 928 5 sp Silver
78 928 AT Euro Black
tj924
PostPosted: Wed Jul 20, 2005 12:25 pm    Post subject: Reply with quote
There are no vacuum lines on the distributor at all, never have been since I've had the car.
The exhaust popping only started after the intake boot had come partially off the plastic tube (one of the brackets had come loose) & the car ran really crappy. Put the intake boot back on & the car runs good again except for this popping sound. Only happens when I take my foot of the gas & the revs are coming back down, doesn't happen at idle or under acceleration.
TJ
PostPosted: Wed Jul 20, 2005 12:51 pm    Post subject: Reply with quote
Is is a nice burbling noise or sharp cracks?
tj924
PostPosted: Wed Jul 20, 2005 1:14 pm    Post subject: Reply with quote
Noticable pops that weren't there before. Not loud, but noticable & not that nice burbling sound.
TJ
PostPosted: Wed Jul 20, 2005 1:35 pm    Post subject: Reply with quote
Does your car have a decel valve? It looks like a big vacuum advance and sits on the intake manifold.
tj924
PostPosted: Wed Jul 20, 2005 1:49 pm    Post subject: Reply with quote
Yep, it has the decel valve (also known as a vacuum limiter right?). It has 2 vacuum lines running to it, both of which I've replaced (just 'cause they were the easiest to get to as I'm replacing all the vacuum lines over a few weekends). Why?
TJ
PostPosted: Wed Jul 20, 2005 2:35 pm    Post subject: Reply with quote
Make sure it is in working condition....
tj924
PostPosted: Wed Jul 20, 2005 2:36 pm    Post subject: Reply with quote
Is there a test in the Haynes for it?
TJ
PostPosted: Wed Jul 20, 2005 2:39 pm    Post subject: Reply with quote
Not sure, but you want to make sure the rubber membrane is not leaking air.
tj924
PostPosted: Fri Jul 22, 2005 11:56 pm    Post subject: Reply with quote
My decel valve only has 2 vacuum lines running to it. I can see a spot for a 3rd small (4mm) line on the bottom of the valve but it is not hooked up. Should this be connected?
OK, so here is what my vacuum lines look like...
Anyone else with an '82 NA able to give me a comparison?
TJ
Gram
PostPosted: Sat Jul 23, 2005 2:23 am    Post subject: Reply with quote
My '82 NA doesn't have any of the braided lines shown in blue..no carbon cannister, decel valve etc. (Continue the black rubber hose to the brake booster for mine). The small hose (I think you show in brown) runs from the throttle body to the distributor (and only one port on each). Car is ex UK..imported here in '85.
'82 924 NA Euro (hers)
'98 Audi A4 TDI (ours)
gohim
PostPosted: Sat Jul 23, 2005 6:53 am    Post subject: Reply with quote
Seems like the advice that others have offered is more complexed than what may actually be worng...
Have you checked the camshaft timing belt to make sure that it has not jumped timing, is correctly tensioned, and has not stripped any teeth?
This could VERY EASILY explain the way that your engine is running.
tj924
PostPosted: Sat Jul 23, 2005 8:55 am    Post subject: Reply with quote
Had the timing belt off last weekend to change the water pump. Made sure it was put back on right (after some effort as the timing would go out every time I tensioned it, so it took a few times to get it right). I have checked it again after a few runs & it is still lined up dead on, so hasn't jumped & the belt is in good nick.
TJ
PostPosted: Sat Jul 23, 2005 9:05 am    Post subject: Reply with quote
Yes, that hose is the one that activates the valve.
