931 to 924 swap
Cbass
Guest
PostPosted: Thu Mar 28, 2002 3:35 pm    Post subject: Reply with quote
Can anyone outline the major difficulties in building a 931 motor out of a running NA motor and a non running 931?
dwak
Guest
PostPosted: Thu Mar 28, 2002 9:33 pm    Post subject: Reply with quote
I can't see any problem other than usually the 931 specific parts are the damaged ones and you usually end up turning a 931 into a 924. As in smashed head, pistons and valves in the 931.
dwak
Rick MacLaren
Guest
PostPosted: Fri Mar 29, 2002 12:08 am    Post subject: Reply with quote
I find getting enough money is usually the toughest part...
Zuffen
PostPosted: Fri Mar 29, 2002 1:23 am    Post subject: Reply with quote
You can use everything but the pistons, too low a compression for a NA. What is your plan?
Bob Dodd - 924turbo@cox.net
