J1NX3D
Joined: 06 Feb 2003 Posts: 1333 Location: New Zealand
Posted: Wed Mar 16, 2005 11:20 am Post subject: head gasket? |
Hi all,
was driving my car, let it warm up normally, drove for an hour (not at all hard) and came back, all guages reading normal except engine temp was up. When I parked up there were thick plumes of white smoke coming out the exhaust, I could hear coolant boiling over in the overflow tank.
i left it to run for a couple of mins to see if the temp would come down. It didn't so I shut off. I left it to sit for a lil while then came back to check oil and water. No water in the overflow tank (!!?!?), no milkshake in the oil.
the smoke didn't look or smell oily, it smelt a bit like coolant. Haven't driven it since.
Whats happened?
TIA
-worried _________________ '86 944 |
john h
Posted: Wed Mar 16, 2005 2:10 pm Post subject: Re: head gasket? |
| J1NX3D wrote: | Hi all,
Whats happened?
TIA
-worried |
blow head gasket or cracked head.
Most likely the head gasket is blown but so far it hasn't let go in a way to let the water oil to mix. What's happening is it's sucking the water back into the cylinder when cold (or when you turn the engine off) and this is causing the white smoke. later as temperature rises it's used a fair bit of the water up and is now presurising the cooling system.
Be careful you don't leave it for too long and end up filling up with one of te cylindersfull of water - called hydrauliing(excuse the spelling of this word) - if this happens you could kiss your motor good bye, (water doesn't compress very well) and you could in an extreme case bend a rod.
After my last race meeting the GT did the same thing - except when it gets hot it dumps the water out of the header tank.
Haven't got round to fixing it yet as I'm not planning on using the GT till November so it's been driven into the garage and will become my winter project (June / July) _________________ Remember a Porsche is not just for Christmas,
Posted: Wed Mar 16, 2005 2:47 pm Post subject: |
If its sucking the water into the cyl. it should be hydrolocking
when you try to start it...water doesnt compress like air
so it wont turn over. _________________ 1979 porsche 924 Na
Have u ever driven a turbo. |
Raceboy
Posted: Wed Mar 16, 2005 3:58 pm Post subject: |
It starts, but only, if there is a little water in the cilinder. If theres a lot, then that one, where's the water, doesn't start but others will and you will bend the rod. It's a common problem in 928, only worse: you will not bend the rod, but crack the block ('cause they're made of alloy). _________________ '83 924 2.6 16v Turbo, 470hp
'67 911 2.4S hotrod
'90 944 S2 Cabriolet
'78 924 Carrera GT replica
'84 928 S, sold
'91 944 S2, sold
'82 924S/931 "Gulf", sold
'84 924, turbocharged, sold.
J1NX3D
Posted: Wed Mar 16, 2005 6:40 pm Post subject: |
cheers guys!
[edit] i'll check it out and confirm it. is there anything i should do- preventative maintenance- while i'm at it? I'll probably do the water pump too.
also, whats involved in 'o' ringing the head?
thanks _________________ '86 944 |
Posted: Thu Mar 17, 2005 12:51 am Post subject: |
in order to oring the head you need to take it to a CNC shop and have them cut a groove around the chambers and then put a small wire around the port, this aids in sealing power, as far as preventitive, changing coolant every couple of years is always a good idea, and while in there replace the heater hoses (go to dealer for that) and thermostat. _________________ 3 928s, |
J1NX3D
Posted: Thu Mar 17, 2005 11:25 pm Post subject: |
is a stock head gasket the way to go or is there an aftermarket one better suited?
i have an '80 euro with 7.5:1 compression and i want to eventually have a p&p head, matchported intake manifold, o ringed head, mild grind cam, 951 or 951 style i/c and run 1 bar of boost (i'm pretty much at sealevel). Upping compression wouldn't be a bad thing, i hear 951 tuners mill the head 0.050-0.060" off the head to increase compression, can i do this too? frankly, the off boost peformance of this car could use some work!
i would like to take care of most of the head related work while its off, please tell me if i'm going the wrong way about things!
Cheers!
Jae _________________ '86 944 |
Raceboy
Posted: Fri Mar 18, 2005 4:56 pm Post subject: |
Upping the compression means that IC is absolutely necessary. If you stay with stock pistons and increase off-boost performance, yes, shave a bit but not from head, but from block, because blocks are easier to find in case you want go back to 7.5:1 CR. In situations like you want to achieve: 8.5:1 CR, intercooled @ 1Bar and stock pistons, you cannot let ANY detonation to happen, or you lose your pistons. _________________ '83 924 2.6 16v Turbo, 470hp
'67 911 2.4S hotrod
'84 928 S, sold
'91 944 S2, sold
J1NX3D
Posted: Fri Mar 25, 2005 1:03 pm Post subject: |
thanks race boy
another question: i mentioned to a friend i was thinking of o ringing the head. he said to go with a copper headgaskept instead and i wont need to bother with o ringing. for my application is this true? if so, is there an off the shelf copper headgasket available? what happens if i do both?
cheers _________________ '86 944 |
Raceboy
Posted: Fri Mar 25, 2005 5:02 pm Post subject: |
Well, O-ringing without Cu-headgasket is not good, same goes for Cu-headgasket without O-ringing. I suggest you do them both. Yes, you can buy Copper headgasket, but it's easier to get the needed CAD-file of the gasket (needed for CNC-machine: laser, waterjet etc) buy copper in thickness you needed and got to the shop where they perform the cutting. My friend, who is a designer, made me this CAD-file, if you want this, just e-mail me: porsche@fastestcar.com . I already sent this file to some of our fellow boardmembers (Paul, Mark).
I took the copper and the file to the shop and it cost me ~40$ a piece to cut them But it's Estonia you know, almost everything is cheap here, except gasoline It costs approximately 1$ a liter, can you imagine?  _________________ '83 924 2.6 16v Turbo, 470hp
'67 911 2.4S hotrod
'84 928 S, sold
'91 944 S2, sold
