Cable routing.
MikesCoupeGT
PostPosted: Tue Nov 12, 2013 12:11 am    Post subject: Cable routing. Reply with quote
I have been pouring through all the manuals and online sites I can find but have not been able to find what I am looking for. Maybe you guys can help. How/Where does the Engine Hood release cable run? Pictures would be great. I want to run this properly and make sure that it does not get caught up in the steering rack. Any and all help is much appreciated, as always.
Cheers;
Cheers;
MikesCoupeGT
'76 924
'83 944
''19 Elantra GT N-Line
View user's profile Send private message Yahoo Messenger MSN Messenger
PostPosted: Wed Nov 13, 2013 1:31 am    Post subject: Reply with quote
The cable runs through a dedicated hole (with a grommet) in the firewall, and then right along the frame spar, past the shock tower, and under the airbox (on an NA).
You have to feed the cable UNDER the supports for the shock tower, which you can see in this photo of my Club Sport engine bay if you look closely. On the 931, it is literally fed through the bracket that holds the expansion tank, which keeps it flush up against the frame spar.
This next photos shows the opposite side shock tower supports a little more clearly, and you can see how there is a space at the base of each support up against the sheet metal. This is where you feed the cable (but obviously on the opposite side).
I've never had issues with the hood release getting tangled in the steering shaft, but I have had them get caught up in the headlight assembly. I usually have a couple of extra zip ties handy to prevent this from happening.
PostPosted: Wed Nov 13, 2013 4:48 pm    Post subject: Reply with quote
Turn on the lights. . .they only go up half way but the hood opens!
Classic. BTDT.;
PostPosted: Wed Nov 13, 2013 10:17 pm    Post subject: Reply with quote
MikesCoupeGT
PostPosted: Wed Nov 13, 2013 11:09 pm    Post subject: Reply with quote
Thanks Ideola. Looks like I am missing the routing piece for the cable. Looking at the engine bay of my '24, I have no routing plate. Time to improvise.
Cheers;
Cheers;
MikesCoupeGT
'76 924
'83 944
PostPosted: Thu Nov 14, 2013 2:29 am    Post subject: Reply with quote
Mike,
The 924 NA doesn't have a routing plate. Only the 924 Turbo has one.
Just run the cable through the strut tower braces and into the hood latch, which is exactly how mine is routed.
