Fixed bumper mounts
Kenodog
PostPosted: Fri Dec 19, 2003 6:57 am    Post subject: Fixed bumper mounts Reply with quote
I am thinking about making some aluminum bumper brackets for my car.These would replace the Boge shocks.They will hold the bumper the same distance out as a drilled and compressed Boge.However they will also be lighter by about 4-5 lbs. each.Times 4 per car and there goes 16-20 lbs! Anyway the first set I will fab up myself but if anyone else wants some a friend of mine works in a shearing/forming shop and suggested to make some to sell.So is anyone interested? A set of four (front&rear) with shipping will be about $35-40.Is it worth it?
1979 Euro 931, Olive
1981 931, Sabine
1996 Ford E-350 ex-FedEx Van
2014 Mazda CX-5 (Kinderwagon)
2019 KTM 790 Adventure
2024 KLX300
2024 KLX140
PostPosted: Fri Dec 19, 2003 8:32 am    Post subject: Reply with quote
count me in
3 928s,
Chrenan
PostPosted: Fri Dec 19, 2003 8:41 am    Post subject: Reply with quote
Count me in...
PostPosted: Fri Dec 19, 2003 11:50 pm    Post subject: Reply with quote
Those would seem to be a natural pairing with fiberglass bumpers for racing applications. Perhaps selling them to a retailer would be wise, to improve distribution and volumes? I'd be interested for one of my 931's, but what a PITA to get them over the border, right?
For example:
http://www.fiberwerks.com/
Neil924
PostPosted: Sat Dec 20, 2003 12:15 am    Post subject: Reply with quote
If they were made in canada thenn it should be easy. If they were ... say made in Germany and were from the factory then you would pay more.
PostPosted: Sat Dec 20, 2003 1:32 am    Post subject: Reply with quote
924Racer, actually shipping across the border is no biggy, you label it as a gift no taxes payed, he isn't really pulling profet so it isn't that bad, or he doesn't have a company name for his parts, so it would just be shipped say as a "christmas" gift
3 928s,
Kenodog
PostPosted: Sat Dec 20, 2003 1:54 am    Post subject: Reply with quote
Don't worry about shipping.Lizard is right.I've shipped a ton of stuff to the US using the gift clause and have never had a problem.When I get the first set made I will post pics so you can see what they look like.The aluminum i'll be using is thick enough that i'm not worried about failures.They will be direct bolt on units.Take maybe 10 mins. to do both bumpers.
1981 931, Sabine
2024 KLX300
2024 KLX140
PostPosted: Sat Dec 20, 2003 3:03 am    Post subject: Reply with quote
OK, then, keep me posted!
CBass
PostPosted: Sat Dec 20, 2003 3:19 am    Post subject: Reply with quote
Don't forget to take metal stretch into consideration when bending the brackets.
welder
PostPosted: Sat Dec 20, 2003 11:51 am    Post subject: Reply with quote
Kendog is right, being a welder and machinist by trade these would be very straight forward to build and install. Be aware that without the shocks your bumper won't stand much of an impact without cracking or completly breaking. Although it can also be easly tig welded. When making the new aluminum shock replacements it will most likley be necessary to weld new brakets where the shock meets the bumper cause if you've ever seen this attachment point it's kinda weak and surprisingly flimsy
I have a 78 n\a currently under restoration.
Kenodog
PostPosted: Sat Dec 20, 2003 1:26 pm    Post subject: Reply with quote
O.K.,here are the materials I have to make the first set.If you have the luxury to be holding a Boge in your hand you will understand this. The "U" shaped piece on the end will be identical in size and shape except out of aluminum.The shaft,so to speak is a piece of 1 1/2" square aluminum billet.And for the vertical backing plate I have some 3/8" cold rolled plate.The reason I think aluminum will work as well as steel in the application is because the bumper will be sitting only half the distance away from it's mounting point vs.the stock set up.This means that if you calculate the leverage force applied,it is a much easier load
beingcloser to the solid mounting point.If we have a physisit or an engineer on board please do the math.And like I say,mine will be the testing ground,if i'm not happy with the results I won't sell them.
L,[/b]
1981 931, Sabine
2024 KLX300
2024 KLX140
welder
PostPosted: Sun Dec 21, 2003 1:31 am    Post subject: Reply with quote
Kenodog, your materials sound plenty strong, also I like the idea of being different in length to change the front and rear profile. The weak point I spoke of is where that "U" shaped piece attaches to the bumper, actually part of a weakly fabricated bracket inside and tacked to the bumper. Your replacement will be plenty rugged. Have you ever noticed that when removing all the paint from the bumper before painting exposes numerous spider cracks. If you look inside the bumper you'll see the cracks go completly through the casting. These can be welded up quite easly. These tend to occur when minor impact exceeds the max 5 mph limit for the shock or they are worn out
PostPosted: Sun Dec 21, 2003 1:56 am    Post subject: Reply with quote
Oh, crap, I'm sorry, I didn't realize you meant to use the compressed length of the shocks. I need standard length brackets, will be mounting a fiberglass bumper. Ah well, it's not a priority anyway...
Mikri184
PostPosted: Sun Dec 21, 2003 5:15 am    Post subject: This interest me Reply with quote
I would be interested in getting a set for my car but want to see a finished product first, so get your car done so you can bring it down
Life is to short to be looking for something?
AndyFranklin
PostPosted: Sun Dec 21, 2003 10:02 am    Post subject: Reply with quote
Vaughn,
I'm in the process of fabbing some "imitation" bumpers - similar AN mounts (in concept, at least), 1x3 AN bar, and fiberglass skin. For mine I am planning on shortening them, but making "full length" would be easy.
Of course, I'm not sure I would actually want to use them....
I've been wrong on my IT rules, but I thought you were required to use the stock bumpers. There is no provision for alternate materials. Unless you want to lose the 400 pounds and come play in FProd.
