epsylon
Joined: 05 Nov 2002 Posts: 492 Location: South Padre Island, Texas
Posted: Sat Dec 20, 2003 11:08 am Post subject: 931 torque tube + 944 interchange |
i am getting a loud bearing type noise when idleing in nuetral, goes away when i depress the clutch. i assume this is the torque tube bearings.
my question is are all 944 ( pre 85 and the later ) transmissions and torque tubes the same? do these swap into the late 931s ( 81-82 ) without modification? _________________ '82 931
'78 928
Howell Henderson
South Padre Island |
John Brown
Posted: Sat Dec 20, 2003 1:26 pm Post subject: |
Yes. 944 and late (81/82) 931 can swap the diveshaft housing.
While you're at it don't forget to upgrade to the Ford clutch disc!  _________________ John
80 931 - #931 44Cup
99 Escalade - tows track cars
welder
Joined: 16 May 2003 Posts: 158 Location: cumberland,maine
Posted: Sun Dec 21, 2003 4:13 am Post subject: |
John, I know that clutch change has been discussed here many times, but are you serious that it's a good thing? I'm asking cause I'm about to add the clutch to my new motor and want to save a few bucks. _________________ I have a 78 n\a currently under restoration. |
epsylon
Posted: Sun Dec 21, 2003 5:29 am Post subject: |
the clutch change you are refering to is the one that is a direct plug in play ( ford bronco II ) for the 931 right? not the mustang clutch that is used on the earlier 924 5 speeds conversions to the 944 transmissions and torque tubes. _________________ '82 931
'78 928
Howell Henderson
John Brown
Posted: Mon Dec 22, 2003 2:01 am Post subject: |
First off, I was just teasing. But, yeah, I, and I think Vaughan, have both been more than happy using the BroncoII clutch disc with a 931.
I am probably wrong, but I do not think anyone has listed a replacement disc for the 924 other than OEM. (Using stock 924 shafts).
So it's a project ripe for exploration.  _________________ John
80 931 - #931 44Cup
Posted: Mon Dec 22, 2003 2:40 am Post subject: |
Azndrgn's research suggested the disc for a 90-92 1.8L jetta might work as a replacement for the 924 NA, but:
| azndrgn wrote: | | As I said before this is just what the books say, I haven't checked to see if it will actually work since I don't have a clutch disc to compare it with. |
http://www.924board.org/viewtopic.php?t=9091&postdays=0&postorder=asc&start=15
So, what's left is for someone to give it a trial fitting and see that it doesn't interfere with the flywheel bolts or something else. It's about $47 for the Jetta disk vs $187 for OEM Sachs. _________________ "..it's made in Germany. You know the Germans always make good stuff."
wdb
Posted: Mon Dec 22, 2003 6:02 am Post subject: |
you might call about the 77-79 amc gremlin spirit, concord . the amc flywheel part number is ( 1977-79 4 cylinder (AMC) 325-0437 ) I dont know if the pressure plate is the same , youll have to check the specs to see
http://www.matadorcoupe.com/enginespecs.htm |
wdb
