check valve
PostPosted: Thu Jun 28, 2001 5:06 pm    Post subject: Reply with quote
Email: stevey9@hotmail.com
Date: 28 Jun 2001
Time: 17:06:59
has anyone changed their check valve? Where is it? how much does it cost? How long does it take to do? and is there any special things i need to do to change it?
thanks for the help
steve
PostPosted: Sun Jul 01, 2001 10:01 am    Post subject: Reply with quote
Email: ponzv@aol.com
Date: 01 Jul 2001
Time: 10:01:29
This is the first thing everyone should replace on hard starting. It is a simple job to do and should take about 5 mim. It is at the exit of the in tank fuel pump. Purpose of it is to stop the fuel from running back into the tank. When I replaced mine it was just a fitting with a hole in it. Someone replaced or cut out the valve. should not cost much. I would then check the accummulators, fuel filter and the engine grounds.
Vince
PostPosted: Sun Jul 01, 2001 9:06 pm    Post subject: Reply with quote
Email: l_porsche@hotmail.com
Date: 01 Jul 2001
Time: 21:06:26
where did you find the check valve, the dealer makes you buy the whole pump.
PostPosted: Sun Jul 08, 2001 11:20 am    Post subject: Reply with quote
Date: 08 Jul 2001
Time: 11:20:46
If you need a check valve and they will not sell it to you let me know and I will get one for you. My dealer will sell you anything but Euro parts and I have a Euro that I have to go to Europe to get some parts.
