Headlight not working
Nicke
PostPosted: Tue Aug 07, 2001 12:44 am    Post subject: Reply with quote
I just noticed the left headlight isnīt working. The right one works fine both high- and low beam, the left one has no low beam but the high beam works fine. What could cause this. (I already put in a new bulb, no change, still no low.)
Fuses?
PostPosted: Tue Aug 07, 2001 4:20 am    Post subject: Reply with quote
Yes, the fuses are all individual for each beam; it could also just be a bad contact in a connector.
Bad connector! No Cookie!!!
Nicke
PostPosted: Thu Aug 16, 2001 12:06 am    Post subject: Reply with quote
It was the fuse. Corroded. Looked ok, thatīs why I had to ask this, in retrospect, silly question. Thanks. Adding to the confusion, my normally well informed father said "Of course itīs the bulb! Why the hell would they put in separate fuses for every light?" Well Porsche does...
