Forced air intake
Guest
PostPosted: Sat Jul 28, 2001 11:44 pm    Post subject: Reply with quote
Email: dy15@yahoo.com
Date: 28 Jul 2001
Time: 23:44:46
How would a forced air intake for a 924 na work? Normally you just force the air into the intake box, but in this case there is that air flow sensor. If you force air into there you end up making the sensor give false readings about the air flow and makes the fuel mix wrong. So any idea's on how to keep the correct fuel mix and add forced air intake?
