Mike B Guest
Posted: Fri Aug 03, 2001 10:18 am Post subject: |
Ok...I've read every book, manual and looked at every picture I could find but to no avail..So could someone go have a look under their hood for me...I need to know what connects to the blow by line (crank case vent thing on the block - driver's side)...
I have a line, approx 12 inches long, from that (crank case vent thing)to a connector (Y) which I believe goes to a line to the charcoal cannistor (under the driver's fender)...That leaves one opening on the connector...Where the **** does that go...
Car is a '78 924...Thanks...This is the last problem and then it should fire right up....Ya right |
AznDrgn Guest
Posted: Fri Aug 03, 2001 1:32 pm Post subject: |
If it's the line I think your talking about it goes from the back of the intake plenum splits "y" into the engine block and the other end goes to the charcoal canister. That shouldn't have anything to do with firing though.
Diesel Guest
Posted: Fri Aug 03, 2001 5:35 pm Post subject: |
No other connx. besides that. One end to the air box, the other to the char. can.
