Posted: Sun Jul 20, 2003 6:59 am Post subject: speedo cable help needed asap |
How does it come out of the 924 hub.  _________________ 1979 porsche 924 Na
Have u ever driven a turbo. |
924Kid
Joined: 28 Dec 2002 Posts: 148 Location: 07424, New Jersey, USA
Posted: Sun Jul 20, 2003 10:20 am Post subject: |
When I replaced mine, I took the wheel off (though I don't think you really have to, you may be able to just remove the center cap). There will be a small retaining clip holding the cable in place. The end of the cable being that little square that sticks out of the hub. Remove this clip, and pull the cable out from behind.
The harder part of this whole thing is at the other end where you have to remove the speedo and then snake the new cable under your dash (do this end first when installing, then do the hub). Also refer to chapter 9 in the haynes manual. The section on removing the brake pads & rotors disusses the speedo cable a little. |
Posted: Sun Jul 20, 2003 10:48 am Post subject: |
how about the plastic cable sheath ..so you saying the cable itself pulls outjust the hub is over in the corner with the cable sticking out I cant get it off. _________________ 1979 porsche 924 Na
kaffine
Posted: Sun Jul 20, 2003 12:43 pm Post subject: |
After removing the E clip the sheath just pulls out of the rubber gromet. You might want to spray some WD-40 or silicone spray lube on it. |
Posted: Mon Jul 21, 2003 4:09 am Post subject: |
yup just pull off the c clip and pull really hard from the back of the hub, it will come eventually, might be a good idea to get a new cable before hand _________________ 3 928s, |
