jamez Guest
Posted: Thu Aug 02, 2001 3:43 pm Post subject: |
If I install an after market cam in my car would and work need done to the valves or anything, or is all i have to do is just put the cam in and go? also where is a good place to buy aftermarket cams?
Mike B Guest
Posted: Thu Aug 02, 2001 7:54 pm Post subject: |
I don't believe a higher lift/duration cam can be simply bolted in...It has to be fitted by a machine shop...I don't pretend to know exactly what is required but my personal experience is machine work is necessay....I wasn't very expensive for me...Here are a few places that sell cams for the 924...I picked up a cam from ebs racing for my son's 924 (the project)
http://www.ebsracing.com/water.html
http://www.webcaminc.com/
http://www.paeco.com/home.html |
AppleBit
jamez Guest
Posted: Fri Aug 03, 2001 9:15 am Post subject: |
| So basically I go and buy a performance cam then bring it to a machine shop and have them put it in? |
larso Guest
Posted: Fri Aug 03, 2001 9:34 am Post subject: |
| no, they bolt right in, you just need to buy the lash pads from a place...maybe machine shops have them. i know tweeks has em. |
larso Guest
Posted: Fri Aug 03, 2001 9:39 am Post subject: |
WAIT A SECOND, GET the PERFORMANCE COPS, MAS AND DEISAL, IN HERE. THERE IS A 600 DOLLAR FINE FOR PUTTING A PERFORMANCE MODIFICATION ON A 924
[ This Message was edited by: larso on 2001-08-03 09:40 ] |
