kojab Guest
Posted: Wed Oct 23, 2002 9:07 am Post subject: |
I have enjoyed converting my 924 to Delco EFI and would like to help others follow in the obvious benifits. |
Paul Guest
Posted: Wed Oct 23, 2002 9:10 am Post subject: |
How's the gas mileage and driveability? |
kris Guest
Posted: Wed Oct 23, 2002 9:12 am Post subject: |
Hey Kojab, I looked on the "projects" section & dont know what your actual name is. Which one is yours? (David ewings has a screwed up link...it just takes you to the top of the page when you click on it....) |
Lizard Guest
Posted: Wed Oct 23, 2002 9:17 am Post subject: |
I went there and it didn't have alot of info I could find on converting to EFI
kojab Guest
Posted: Wed Oct 23, 2002 9:18 am Post subject: |
Gas mileage is of course good. The bueaty of the Delco system is its ability to constantly and emmediatley trim for an A/F air fuel ratio of 14.7:1 under cruise conditions. Most other after market ECU system dont have the sofistication that GM spent millions of dollars developing. |
kris Guest
Posted: Wed Oct 23, 2002 9:19 am Post subject: |
I couldnt find alot either Lizzard. Good pictures, but not much detailed info..... |
Posted: Wed Oct 23, 2002 9:24 am Post subject: |
that's great! Love the web site (hate the popups).
Is that a toyota supercharger you're using?
Where abouts is Sydney are you? |
kojab Guest
Posted: Wed Oct 23, 2002 9:27 am Post subject: |
Kris, Sorry I did not direct you to my porsch section on my web page.
Go to Current projects and click on Porsche supercharger installions photos. I dont have much data there on the EFI conversion. I also own the Toyota corolla running Delco with 24 lbs boost. |
kojab Guest
Posted: Wed Oct 23, 2002 9:29 am Post subject: |
Peter, I am in Padstow |
kojab Guest
Posted: Wed Oct 23, 2002 9:32 am Post subject: |
Supercharger on 924 is a Toyota SC14. I am getting 13.5 lbs boost and at present trying to purchase a intercooler as air temps are all ready reaching 125 deg C |
Lizard Guest
Posted: Wed Oct 23, 2002 9:40 am Post subject: |
with a good IC you should be able to drop the temp by 50 deg
Paul Guest
Posted: Wed Oct 23, 2002 9:58 am Post subject: |
But with a supercharger, so will the boost. |
Rick MacLaren Guest
Posted: Wed Oct 23, 2002 10:07 am Post subject: |
Kojab what kind of instrument did you use to measure air intake temperature? Or did you measure closer to the chamber, and if so, how?
I've been trying to locate one...
Thanks. |
kojab Guest
Boost is going to drop slightly whether you have turbo or Supercharger.
I am expecting my 13.5 lbs to drop to 12 lbs.
The nice thing about the supercharger is that there is no boost lag. I have done logs which shows the boost climbs instantly with TPS. |
Paul Guest
Posted: Wed Oct 23, 2002 10:11 am Post subject: |
Boost is maintained by the wastegate therefore a turbo engine can make up for the drop in temp. |
