Fuel Pump not Priming
924-UK
PostPosted: Mon Aug 11, 2025 9:24 pm    Post subject: Fuel Pump not Priming Reply with quote
My car starts without any issues however I have seen so many posts about the fuel pump priming when you turn the ignition on (but not cranking).
My car has never done this. I have removed the fuel pump relay (see attached) and it looks good to me.
Just wondering why this might be?
'84 924 2.0 NA
Beartooth
PostPosted: Fri Aug 15, 2025 10:20 am    Post subject: Reply with quote
I've got the same relay, and mine doesn't cycle the pumps with the key on. As far as I can tell, it doesn't do anything until it gets the ignition signal (pulls off the coil circuit), and it shuts off a second or two after the ignition stops - I can hear the pump run momentarily when I shut if off. My Mercedes with KE-jet cycles the pumps when you turn the key on - if you just turn the key to run, you can hear them come on for a few seconds, then stop. I think that was common to KE-jet cars, but I don't know if any K-jet cars had that logic built into them.
1980 931 diamond in the rough
924-UK
PostPosted: Fri Aug 15, 2025 6:09 pm    Post subject: Reply with quote
Thanks, I watched a YT video with a 924 the same year as mine and his did not prime either.
Yeah, I can hear mine run for a split second after I finish cranking.
As I said, it starts on the button now.
'84 924 2.0 NA
