Ignition lock bearing play
PostPosted: Sat Jul 19, 2025 3:59 pm    Post subject: Ignition lock bearing play Reply with quote
Hi,
Replacing the ignition switch, I noticed a lot of play on the steering wheel bearing that is inside the ingtion lock holder.
I have a 1979 924, with the steel switches for wiper/blinker.
Is see you van buy the bearing: 911 347 771 02, but very expensive, is there an alternative from VW?
Picture as example:
chuck21401
PostPosted: Sun Jul 20, 2025 3:44 am    Post subject: Reply with quote
Found 911 347 771 02 on this dealer's website.
https://www.sunsetporscheparts.com/oem-parts/porsche-ball-bearing-91134777102
Note this reference " Replaces: 111-953-559-A, 111-953-559-C, 911-347-771-00 "
Searching on 111-953-559-A and 111-953-559-C brings up VW parts.
This EBay listing has clear pics along with dimensions to check
https://www.ebay.com/itm/326439986723
Beartooth
PostPosted: Mon Jul 21, 2025 2:00 pm    Post subject: Reply with quote
If you can find a used one cheap enough, I'd give that a shot. Mine seemed to be in great shape despite the condition of the rest of the car; I had it all apart while I was replacing the ignition switch and turn signal switch assembly, so I packed it with new grease and put it back together. It's a similar story with the rest of the steering gear: all that's been replaced is the rack and pinion bellows, and the steering is just as tight as my 560SEC was with a new steering box and several other new parts. It doesn't seem like a part that would get sloppy - maybe lots of miles, or a lot of aggressive driving?
1980 931 diamond in the rough
Raize
PostPosted: Tue Jul 22, 2025 1:15 am    Post subject: Reply with quote
The bearing in mine was actually sloppy in the housing, weirdly enough. The bearing itself was fine. I used a centre punch on the metal at the outside edge of the bearing to expand it and make it a solid fit.
