Which clutch do I buy? ($20 reward)
SpreadTheTed
PostPosted: Mon Aug 09, 2021 1:42 pm    Post subject: Which clutch do I buy? ($20 reward) Reply with quote
Hey all, I am knee deep in a 931 engine swap and I've been stuck for almost 3 weeks now buying and returning clutches, and I need some HELP. I have a 1982 931/2, I am trying to buy a clutch for it, a 944 does not fit, I took the one off my base model 944, trust me I tried, I just need to know what WILL fit. A 944 turbo clutch definitely looks like it would fit but I can't tell until I buy one and I've spent about $150 so far shipping back returns so I'm not about to take a shot in the dark again.
JUST IN CASE THIS HELPS:
the bolt pattern is the same as the 944 pressure plate, but the plate protrudes out too far and won't fit, the flywheel is completely flat with no lip like a base 944 flywheel.
I'll venmo $20 to whoever can lead me to the clutch that fits
I would much prefer a kit rather than slapping a bunch of different part numbers together but if that's what I need to do so be it
PostPosted: Mon Aug 09, 2021 1:50 pm    Post subject: Reply with quote
I have no idea, but it’s pretty cool to see a bounty around here!!
PostPosted: Mon Aug 09, 2021 3:27 pm    Post subject: Reply with quote
There are companies who repair&upgrade your clutch disk.
Take the old one to them and tell them to mod and repair that one.
SpreadTheTed
PostPosted: Mon Aug 09, 2021 10:22 pm    Post subject: Reply with quote
Old one is done in, there are a bunch of broken fingers on the pressure plate and I actually tossed the friction disc
PostPosted: Tue Aug 10, 2021 1:45 am    Post subject: Reply with quote
Isn't the issue that you have the US special s1/s2 mixed clutch/flywheel arrangement? So the 944/ 931 s2 kit won't fit. There should be threads around here on that subject.
jacobroufa
PostPosted: Tue Aug 10, 2021 7:15 am    Post subject: Reply with quote
There's a pretty thorough section of this post https://www.924board.org/viewtopic.php?p=218956#218956 which includes a section on clutches, with several links that might be helpful..
1980 Porsche 931
1981 Porsche 924 Weissach
anthonimartini
PostPosted: Thu Aug 12, 2021 1:06 pm    Post subject: Reply with quote
im using a aluminum sachs pressure plate from a 911 sc and a 1988 ford aerostar clutch disc. any 911 fitted with a 915 gearbox will have a compatible pressure plate and a 944 throwout bearing and pilot bearing will work.
https://www.ebay.com/itm/263993572779
ive saved alot of 924's
current:
79 MochaSchwartz 931
83 944
87 924S
formerly known as turbellion, lost password.
