Al holbert 924 questions engine swap
Boogieman28
PostPosted: Wed Jul 15, 2020 6:34 am    Post subject: Al holbert 924 questions engine swap Reply with quote
I Got a 924 Porsche with the al holbert body kit itís something like the 900th 924 ever imported in the us. So I have lots of time on my hands and was thinking about engine swaps since the little 2.0 doesnít do much for me. I was thinking an ls a Audi 5 or a 1.8. I know some people will say that to just get a 924s or 944 but this car is kinda different. The previous owner fixed all the rust places but a small one in the fender. Brand new floor one and the car itself is in good shape and I know trying to take the body kit off will probably do more harm than good.
For any swap Iíll have to fabricate a crossmember or find a way to put a 944 crossmember under the car. It has a 944 transaxle in the back. Itís not going to be a daily driver or even close. Itís going to be purely a race car that I can drive up the road to get gas. The interior is completely gutted and it has 944 from suspension and brakes. It has the block of the 2.0 in it but the parts are so expensive and itís a bore of a motor to me.
What do you guys think about swaps is it too much work to change the torque tube and crossmember to put say an ls in or should I just keep the car and find another? If you guys think I should swap it tell me which engine I should go with thanks.[/list]
PostPosted: Wed Jul 15, 2020 6:47 am    Post subject: Reply with quote
Audi 5cyl FTW!
Any!
Boogieman28
PostPosted: Wed Jul 15, 2020 6:50 am    Post subject: Reply with quote
Have you done this swap what exactly would I need to do to complete the swap the only accessory I would really need would be an alternator and a water pump if you consider it a ďaccessoryĒ. Also Iíve read the Audi motor fits right in and Iíve read itís no where close
PostPosted: Wed Jul 15, 2020 2:19 pm    Post subject: Reply with quote
Turbo LS on a snail trans
PostPosted: Wed Jul 15, 2020 4:20 pm    Post subject: Reply with quote
well nothing is bolt on...except the audi bellhousing..its still a swap nomatter what engine you choose but the 5 cyl do sound very special
PostPosted: Wed Jul 15, 2020 5:24 pm    Post subject: Reply with quote
Turbocharge the engine that is already in there, much less work.
PostPosted: Wed Jul 15, 2020 6:30 pm    Post subject: Reply with quote
This........ https://www.boostbrothersgarage.com/944-07k-swap
PostPosted: Wed Jul 15, 2020 6:32 pm    Post subject: Reply with quote
Or this ....... http://www.motorwerksracing.com/18t-engine-installation-components
Boogieman28
PostPosted: Thu Jul 16, 2020 10:15 pm    Post subject: Reply with quote
I think Iíve decided on a 07k the junkyard almost right next to my house has 4 cars with the 07k in there it seems like the biggest problem is trying to figure out the crossmember on a 944 but since I have no power steering I might be able to cheat that a little bit the reason I went with a 07k is because that this car was converted to carbs long ago and all the components to put it back would be a pain to find and along with expensive it would probably come up to just about as much fixing the stock engine than swapping in a newer fuel injected engine. Another problem is that our 924s have cable clutches and pretty much any engine swap would require a hydraulic clutch.
