Joined: 08 Jun 2010 Posts: 1014 Location: Maysville, Colorado
Posted: Sat May 23, 2020 10:43 pm Post subject: Oil Pressure Gauge |
On my day '77 day car the oil pressure gauge is pegged when the ignition is turned off/battery disconnected. Does that mean the gauge is kaput? _________________ Mike
'77 924
cricketdesigns.com |
Joined: 29 Jul 2001 Posts: 8421 Location: Royal Oak, MI, USA
Posted: Sun May 24, 2020 10:08 pm Post subject: |
Does it do that all the time, with ignition on, or just when you shut it off?
Normally that would indicate a short to ground, somewhere in the circuit between the gauge and the sensor. _________________ Vaughan Scott
'79 924 #77 ITB racecar
Posted: Sun May 24, 2020 11:49 pm Post subject: |
I'll check it out, thanks. These guys never have wiring problems -right? Currently getting a new head gasket(Cometic ) and ARP studs, about had it with these 40 year old head bolts. _________________ Mike
'77 924
