Oil Pressure Gauge
PostPosted: Sat May 23, 2020 10:43 pm    Post subject: Oil Pressure Gauge Reply with quote
On my day '77 day car the oil pressure gauge is pegged when the ignition is turned off/battery disconnected. Does that mean the gauge is kaput?
Mike
'77 924
cricketdesigns.com
PostPosted: Sun May 24, 2020 10:08 pm    Post subject: Reply with quote
Does it do that all the time, with ignition on, or just when you shut it off?
Normally that would indicate a short to ground, somewhere in the circuit between the gauge and the sensor.
PostPosted: Sun May 24, 2020 11:49 pm    Post subject: Reply with quote
I'll check it out, thanks. These guys never have wiring problems -right? Currently getting a new head gasket(Cometic ) and ARP studs, about had it with these 40 year old head bolts.
Mike
'77 924
cricketdesigns.com
