Found a mysterious relay...
felix83
PostPosted: Thu Apr 23, 2020 4:45 pm    Post subject: Found a mysterious relay... Reply with quote
Yesterday I found this relay in the battery box. The wiring going to it looks like it could have been done at the factory, but what does it do? The car has been on SORN since 2008 and I bought it a couple of months ago.
Edit: It's a 1977 Euro car.
Felix
'77 924
'82 911 SC
Instagram: @orebro.classics | @924.resurrection
dogleg5
PostPosted: Sat Apr 25, 2020 11:57 pm    Post subject: Reply with quote
Weird. I've tried searching both the numbers on the relay and nothing. My guesses are, headlight washers, security system, fog lights.
You could try starting the car and turning everything on and then unplug it and see what stops working. If the car dies, then you know it's something with fuel or ignition (which could be security system if you have that).
Nobbi
PostPosted: Sun Apr 26, 2020 4:39 pm    Post subject: Reply with quote
Hello,
that relay is factory solution for the hot-start issue.I am not sure how it works but it builds up fuel pressure in the lines.
Nobbi
NA 924 - april/1977- 4-speed-audi gearbox.
500.000 km with fun.....and new toy:Porsche 944 S2 Cabriolet.Other car Daimler c-class cabby,brandnew!
Plus new in the stable..1982 NA in grand prix white.Plus : DEUTZ 4005 tractor Built 1969
felix83
PostPosted: Tue Apr 28, 2020 5:21 pm    Post subject: Reply with quote
Nobbi wrote:
Hello,
Nobbi
Thanks! The engine starts fine without it (The ground cable had come off) but I haven't tested how well it starts when warm so that might very well be it. I traced the cable back, and it connects to a sensor at the back of the engine block.
Felix
'77 924
'82 911 SC
PostPosted: Tue Apr 28, 2020 9:09 pm    Post subject: Reply with quote
That sensor is probably the thermo time switch? Back of the head?
Or is it a 2-prong switch in the coolant line under the ignition coil?
