924 2.0 NA flywheel lock - help needed
Witty924
PostPosted: Thu Nov 07, 2019 7:29 am    Post subject: 924 2.0 NA flywheel lock - help needed Reply with quote
Hi all,
Need a little help on removing the infamous crank bolt. I need to track down a flywheel lock for my 924 2.0 NA. I can only find locks for the 924 s 2.5l or 944 and wondered if they happened to be the same size starter ring with teeth spacing as the 2.0l NA.
I have tried the home approach of locking in gear with brakes on but still too much play in the transmission/clutch so canít crack the bolt off.
I donít have access to air tools or impact gun so looking for the lock as my only option.
Thanks in advance
Witty
Witty924 - Porsche 924 2.0l NA 1984
Ozzie
PostPosted: Thu Nov 07, 2019 8:06 am    Post subject: Reply with quote
Having an auto NA I couldnt put in gear and undo mine either.
The work around (not recommended) for me was remove the coil HT line to dissy and using a long breaker bar.
Lock the breaker bar against the chassis and briefly crank the engine. this loosened the crank nut so I could remove the pully.
Its AUTO and its BLACK
Montego Black on black/red
Witty924
PostPosted: Fri Nov 08, 2019 12:06 am    Post subject: Reply with quote
Thanks Ozzie,
Very creative
Did you have any issues with the bolt after that, rounded head etc?
Thanks
Witty
Ozzie
PostPosted: Fri Nov 08, 2019 7:34 am    Post subject: Reply with quote
no, all good after.
Removing HT lead from coil is a must, heard stories of engine starting when others have tried this.
I also used loctite when replacing
Witty924
PostPosted: Sat Nov 16, 2019 10:11 am    Post subject: Reply with quote
Thanks Ozzie
Appreciate the reply.
Will let you know how I get on
Svobodin
PostPosted: Sat Nov 16, 2019 9:48 pm    Post subject: Reply with quote
944 flywheel lock should work... the 944 has the same starter, I have swapped those between models, so I don't see why the flywheel lock wouldn't bolt up.
1980 Porsche 924 turbo (Project)
1980 Porsche 924 turbo M471 (Project)
1983 Porsche 944 (Daily)
1984 Porsche 944 Sunroof delete (Project)
Witty924
PostPosted: Sun Nov 24, 2019 11:35 am    Post subject: Reply with quote
Thanks SVO
Couldnít find any info on a 2.0l vs 2.5l and starter ring differences.
If you have used a lock on both types and it worked thatís good to know
