NA 924/931 with M471 option.
AnthonyM
PostPosted: Fri Nov 08, 2019 9:19 pm    Post subject: NA 924/931 with M471 option. Reply with quote
Iím considering purchasing a 1980 924/931 M471 that appears to have all of the correct parts/options to be authentic. These cars appear to be somewhat uncommon and donít want to overpay. Would the value of these cars be closer to the value of a NA or a 931? This would be based on a good condion/ lower mileage driver.
Will the option codes be listed on the rear panel like a 944?
PostPosted: Fri Nov 08, 2019 9:46 pm    Post subject: Re: NA 924/931 with M471 option. Reply with quote
So it is an NA with M471? 5 lugs and upgraded sways and stuff but not a turbo?
I think a good solid M471 NA should fetch like $5k but I doubt the market agrees with me.. You can probably get a really good one for like 3..
AnthonyM
PostPosted: Fri Nov 08, 2019 10:30 pm    Post subject: Reply with quote
Yes. It has all of the equipment.
PostPosted: Sat Nov 09, 2019 6:23 am    Post subject: Reply with quote
M471 also has the limited slip.
1979 924 NA race car
1982 924 Turbo almost a PoS
Brockoli
PostPosted: Fri Nov 15, 2019 9:51 am    Post subject: Reply with quote
My 1980 924 had the 5 lug hubs, 944 NA brakes and upgraded suspension but I dont think it has an LSD....at least it doesnt act that way on the track. It didnt have the option tag by the tail light so no idea if it actually is a M471 but it has all the other options.
PostPosted: Tue Nov 19, 2019 5:28 am    Post subject: Reply with quote
Pretty sure LSD was not part of the M471...it was an option, but I have seen and owned many M471-equipped cars that did not have it.
