Juho
Posted: Tue Jan 12, 2021 7:56 pm Post subject: |
You think gazs would be a good upgrade compared to ta technix coilovers front and bilstein strut in back, just thinking of it because gazs would be easier to get pass inspection |
Juho
Posted: Tue Jan 12, 2021 10:13 pm Post subject: |
does anyone have tuv papers for bilstein b36-016? |
safe
Posted: Tue Jan 12, 2021 10:28 pm Post subject: |
Is TUV relevant to Finland?
Aren't you allowed to change suspension? _________________ /Magnus, Stockholm Sweden
Porsche 924 -79 NA, under EFI and turbo conversion |
Do you actually have such absurd laws there that you have to use the same make of shocks? _________________ SUPERCHARGED Ruby-sh 924 |
Juho
Posted: Tue Jan 12, 2021 10:32 pm Post subject: |
you need some kind of papers here to register the car with new suspension components |
Juho
Posted: Mon Feb 01, 2021 4:12 am Post subject: |
Bought 944 s front swaybar but the side mounting is different what should i do? use the side mountings from the old sway bar or what? |
safe
Posted: Mon Feb 01, 2021 4:59 am Post subject: |
Juho wrote: |
The 944 uses a different mount both to the suspension arms and to the body.
Check the PET for exploded view pictures/drawings and part numbers. _________________ /Magnus, Stockholm Sweden
Joined: 08 Jun 2010 Posts: 993 Location: Maysville, Colorado
Posted: Mon Feb 01, 2021 5:22 am Post subject: |
Look thru the "How to" section. Years ago I did a how to on it. It requires changing to the 944 steel control arm, they are inexpensive over here, about $25. _________________ Mike
'77 924
cricketdesigns.com |
Juho
Posted: Mon Feb 01, 2021 5:57 am Post subject: |
Thank you, what about the rear swaybear will it bolt on? |
Posted: Tue Feb 02, 2021 12:15 am Post subject: |
If it has the brackets welded to the TB carrier it will bolt on. New bushings probably required. I had to make new mounting plates for the front and it was a photobucket picture which may not show up. If you need it I could email it to you. _________________ Mike
'77 924
Juho
Posted: Wed Feb 03, 2021 6:08 am Post subject: |
MikeJinCO wrote: | Look thru the "How to" section. Years ago I did a how to on it. It requires changing to the 944 steel control arm, they are inexpensive over here, about $25. |
i keep getting same pn for 944 and 924 control arms |
Posted: Wed Feb 03, 2021 7:21 am Post subject: |
They don't make the 924 control arms with the sway bar mount out front anymore. The 944 arms have the holes in the arm for the 944 sway bar bushing clamp and bushing. Look at a 924S/early 944 parts diagram. _________________ Mike
'77 924
Juho
Posted: Wed Feb 03, 2021 9:00 am Post subject: |
My front sway bar needs a control arm like this
Can i just swap the control arm mount from the 924 sway bar into 944s swaybar?
Harm
Posted: Wed Feb 03, 2021 9:22 am Post subject: Re: 1 stud build |
^Those won't fit.
You need the common VW Golf Mk1 part (McPherson suspension)
Make sure it includes holes to connect the sway bar.
The other parts you'll need shown hereā¦
Juho
Posted: Wed Feb 03, 2021 9:27 am Post subject: |
but my 944s sway bar has a different type of mounting to controll arm
