Replacing the Rear Main Seal??
Goto page Previous  1, 2
PostPosted: Sun Mar 03, 2019 7:01 am    Post subject: Reply with quote
What a nice guy!
K-Roll931
PostPosted: Mon Mar 04, 2019 4:31 pm    Post subject: Reply with quote
Kenodog wrote:
If y'all need lines I have about 5 good sets. A set is yours for the shipping...
Leigh
I will gladly take you up on such a kind and generous offer!! I would appreciate it greatly!
'80 931 M471 - Dolomite Gray -> Monaco Blue
Kenodog
PostPosted: Tue Mar 05, 2019 9:56 am    Post subject: Reply with quote
No problemo, just PM me your shipping address and I will get a quote. Most likely be about $20-$25 for shipping.
Leigh
1979 Euro 931, Olive
1981 931, Sabine
2014 Mazda CX-5 (Kinderwagon)
2008 GS500
2016 DR650
2019 KTM 790 Adventure
K-Roll931
PostPosted: Tue Mar 26, 2019 10:30 am    Post subject: Reply with quote
Sorry! Forgot to say "PM'ed" for the longest time. In other news it seems by process of elimination, the oil pressure sender may be what's leaking.
Getting to that bugger while in the car, might lose a hand or two and use some choice words on this one.
K-Roll931
PostPosted: Wed Aug 28, 2019 8:33 am    Post subject: Update-ish Reply with quote
Oil pressure sender, and the distributor gaskets have been replaced in the last two months. The head is no longer leaking oil. That's wonderful.
However....I'm still dripping (not leaking) oil consistently from the engine. Ignoring the leaks on the rear of the pan, I was a dingus and reused the crush washers for some reason.
I'm getting oil leaking mainly around the bellhousing and starter motor. While this does suck, I'm just glad I'm not smoking oil like I did prior. Now it's just an occasional and subtle whiff.
PostPosted: Wed Aug 28, 2019 10:55 pm    Post subject: Reply with quote
That's great to hear!
K-Roll931
PostPosted: Wed Oct 30, 2019 9:20 am    Post subject: Ready To Start! Reply with quote
Tomorrow I start my conquest on what I hope is the LAST major oil leak on the car! I think I've got the process for this job down, if not, I'd appreciate some input!
I "color coded" the image for reference
1. Drop the exhaust from the turbo back (yellow oval).
2. Disconnect the rear axles from the transmission (red diamonds).
3. Dismount the transmission fom the rear suspension (blue rectangles).
4. Unbolt the torque tube from the bellhousing and slide it back (black arrow). Then remove starter and bellhousing.
I also still need to replace my leaking oil cooler lines (Kenodog, if you've still got a set available...). And while I'm there, I'll replace the shifter bushings at the trans, and inspect the clutch and such.
Page 2 of 2
