16again2009
Posted: Thu Oct 26, 2017 9:41 pm Post subject: Noisy suspension |
I have a 1988 924S. Whenever I drive down an even mildly bumpy road my suspension bangs and bumps and creaks. It has new shocks, new tires, new brakes. I checked everything and nothing is loose. The trans mounts are good. I've never driven a different porsche so I have nothing to compare to. Is the just the way they sound or do you think something is wrong. Thanks for your help. _________________ 1988 porsche 924s
5 speed |
16again2009
Posted: Fri Oct 27, 2017 11:27 pm Post subject: |
Maybe the better question would be when you go down a bumby road does your car ride smooth like a cadillac or more bumpy like a log wagon? Or do you guys even drive your cars? _________________ 1988 porsche 924s
5 speed |
Eric P
Posted: Sat Oct 28, 2017 1:30 am Post subject: |
| 16again2009 wrote: | | Maybe the better question would be when you go down a bumby road does your car ride smooth like a cadillac or more bumpy like a log wagon? Or do you guys even drive your cars? |
I don't have my S on the road yet, but I have been rippin' the 1980 around for a summer. My suspension is fairly quiet with the exception of a fairly loud clunking noise on the rear driver side if I hit a large pothole or speed bump. I looked it over quick and didn't see anything out of the ordinary but I haven't had a chance to investigate it further. At any rate, I doubt it's a normal noise. The suspension is a bit stiffer than a Cadillac and doesn't offer that "floating" feeling on a bumpy road. I can't say I've ever ridden on a log wagon, so you're on your own there.
If you have a lot of noise, you should probably investigate. You may have old worn out bushings, dry ball joints, or something else that needs attention. At any rate, you shouldn't be able to hear your suspension over the creaking and rattling noises coming from the dash  _________________ 1980 924 NA, US model
1987 924S, US model |
Posted: Sat Oct 28, 2017 2:41 am Post subject: |
Grab your exhaust pipe and try to wiggle it all around. It may have a broken hanger and is banging on the body or suspension somewhere. _________________ 1979 924 NA race car H-Prod SCCA
1981 924 Turbo sold
1982 924 Turbo sold
16again2009
Posted: Sat Oct 28, 2017 7:34 am Post subject: |
Thanks guys for the input. I shall investigate further. Now I know it is not normal. I checked the exhaust and it is fine. It sounds more like something is going up and down and making a noise(if that makes any sense). I have brand new boges on it so I know its not the shocks. I shall investigate the rubber bushings. Thanks again. _________________ 1988 porsche 924s
5 speed |
