110 octane leaded fuel
Schwami
PostPosted: Sat Sep 02, 2017 2:53 pm    Post subject: 110 octane leaded fuel Reply with quote
Any ideas what 2 gallons of this blue flame fuel would do to my injection, compression etc systems?
1979 924 Diamant Zweischicht.
Serial # 9249201031
XG 309 543 engine code.
2012 Golf Sportwagon TDI
3forall
PostPosted: Sat Sep 02, 2017 11:10 pm    Post subject: Reply with quote
Injection- Nothing unless it has significantly more/less detergents compared to regular pump gas, but I would assume it's similar.
Compression- Fuel won't change your compression but since you would be running much higher octane you would lose power unless you change either timing or the compression ratio of your engine.
Systems- If you have a catalytic converter on your car the lead in the fuel would wreck it, making it permanently ineffective.
There's no reason to put 110 octane leaded fuel into a street car.
1981 924 Weissach edition
1982 931 - Megasquirt and liquid intercooler
1969 911
Schwami
PostPosted: Sun Sep 03, 2017 7:58 am    Post subject: Reply with quote
Thanks. Now I don't need to justify $7.65/gal. I removed the cat earlier this year, put a header and replaced the pipes with only a muffler. Back to the 87 octane. :)
Serial # 9249201031
daniel
PostPosted: Tue Sep 05, 2017 11:41 am    Post subject: Reply with quote
The only advantage without upping your compression is you can advance timing and run a bit richer. Gains will be minimal without a compression increase
1989 944 Cabriolet
