Denvic
Joined: 28 Nov 2015 Posts: 16 Location: Cobble Hill, BC, Canada
Posted: Fri Jun 30, 2017 12:03 am Post subject: 1979 924 - pickup wire at distributor |
I have no spark and during troubleshooting discovered an intermittent connection at the distributor where the cable from the transistorized ignition box hooks up. The cable appears to be a shielded single conductor that goes into a molded connector. I've had no luck finding a replacement cable and connector, so I may have to do something creative. Can anyone suggest a source for a replacement cable and connector, or failing that, a work around?
Thanks |
