Milling Block
PostPosted: Fri Nov 11, 2016 6:39 am    Post subject: Milling Block Reply with quote
How much can the block be milled before running into cam timing problems? Looking at maybe .013 to .015 inch.
Are any offset cam pulley keys available?
We have had to already mill .006 off the head.
Mike
'67 MG Midget Dp
PostPosted: Fri Nov 11, 2016 8:14 am    Post subject: Reply with quote
Dan (Ideola) has a compression ratio calculator on his site that shows various amounts of shaving possible and the resulting CR. There is a minimum thickness for the head since the valves already stick out and a maximum that can be taken off the block based on that.
When I shave my blocks (to the max on Dan's page) it winds up exactly 1 tooth on the cam so it isn't retarded. I did see somewhere though that Dodge has offset keys for their old 4 cylinder cars from the '80s - '90s.
1981 924 Turbo sold
1982 924 Turbo sold
PostPosted: Fri Nov 11, 2016 8:25 am    Post subject: Reply with quote
Also, there is a wide selection of Mk I Golf adjustable pulleys available.
PostPosted: Sat Nov 12, 2016 11:30 pm    Post subject: Reply with quote
As far as I am aware, there is no wear limit specified for the block. In my experience, you don't want to take the block too much below 231mm, measured from the bearing cap mating surface to the head mating surface. If you need to go below 231mm, you can compensate with a thicker Cometic head gasket. The compression ratio calculator is here, and THIS PROFILE will give you the starting point for a US-spec S1 build. You can specify different block heights and Cometic gaskets to see how it works out, and how much piston to deck clearance you'll end up with.
I also have an adjustable cam sprocket:
