Shurick
Joined: 15 May 2005 Posts: 524 Location: Russia, Moscow.
Posted: Wed Oct 12, 2016 3:03 am Post subject: Flywheel dimensions |
I need to know it thickness. From crankshaft flange to clutch disk area.
Does anyone have this info? Or maybe someone have a flywheel laying around to measure it? _________________ WBR, Shurick
'86 924S -- R.I.P.
https://www.instagram.com/ru_pacecar/ |
Joined: 28 Feb 2008 Posts: 1354 Location: Washington DC area
Posted: Wed Oct 12, 2016 8:01 am Post subject: |
I measured 24.5 mm from the flywheel face through the bolt holes to the clutch face. I don't know if my 931 flywheel has been turned or not. _________________ 1979 924 NA race car
1982 924 Turbo almost a PoS
Shurick
Posted: Thu Oct 13, 2016 9:09 pm Post subject: |
Fifty50Plus wrote: | I measured 24.5 mm from the flywheel face through the bolt holes to the clutch face. I don't know if my 931 flywheel has been turned or not. |
Thanks a lot! _________________ WBR, Shurick
'86 924S -- R.I.P.
Shurick
Posted: Thu Oct 13, 2016 11:40 pm Post subject: |
Do the clutch face sit flush with spring plate mounting surface? _________________ WBR, Shurick
'86 924S -- R.I.P.
Posted: Fri Oct 14, 2016 1:41 am Post subject: |
Yes. _________________ 1979 924 NA race car
