Is my cam timing off?
Johann
PostPosted: Fri Sep 02, 2016 7:09 am    Post subject: Is my cam timing off? Reply with quote
Gentlemen,
I really need your help.
My car running really rough when idling and I am think that my cam timing is off by about one or possibly two teeth. From what I can figure out it is a little late.
This is what I am seeing:
Flywheel
Pulley
Cam (Screwdriver is there for reference to correct paralax issues)
I replaced the timing belt recently, but I don't believe that I moved anything. The car ran rough before I did this too, but it did not move for 20 years.
I really hope that my rough running is as simple as advancing the cam timing slightly.
I am going out of my mind
Oh and it is an S2, euro spec with DITC
PostPosted: Fri Sep 02, 2016 10:27 am    Post subject: Reply with quote
Correct the timing then do a compression test, that much timing error is unlikely to have bent anything.
Johann
PostPosted: Fri Sep 02, 2016 9:24 pm    Post subject: Reply with quote
Thanks for the advice. I am 100% sure there was no interference I checked for that before I started it. It was driving well it just idles like a dog. I am busy fixing my blunder
