Totally seized rear drum.
Wobblydriver
PostPosted: Mon Jul 18, 2016 10:12 pm    Post subject: Totally seized rear drum. Reply with quote
HELP!!!
I have a neglected 924 with seriously seized rear drums. Both sides are locked solid. A drum puller just pushes the drive shafts out. She's been parked up hand brake OFF, in gear for years. How do I get the drum off to clean everything out?
I Know the Voices aren't real, but boy! They come up with some good ideas!
PostPosted: Mon Jul 18, 2016 10:32 pm    Post subject: Re: Totally seized rear drum. Reply with quote
Wobblydriver wrote:
HELP!!!
1st just start tapping/beating the drum from the sides with a rubber mallet to try and loosen things
Wobblydriver
PostPosted: Mon Jul 18, 2016 11:57 pm    Post subject: Seized drums. Reply with quote
Ive tried hitting it with assorted hammers. Nothing happening! Drum doesn't even spin. I'm now at the point where I just want to smash them to get them off! Would heating it with a hand held butane torch help?
agfisher
PostPosted: Tue Jul 19, 2016 12:41 am    Post subject: Reply with quote
I had the same issue. What I need to do was get behind the drum and back off the adjustment screw to bring the pads in. Once the adjustment screw is loosened up bang it with the mallet. That's what worked for me.
Adam
1977 924 N/A Martini Edition
Defender405
PostPosted: Tue Jul 19, 2016 1:10 am    Post subject: Reply with quote
You probably can't get it hot enough with a butane torch to really accomplish anything. I had this happen on an MG once, I had to futz with the adjustment bolt assembly and get it backed out all of the way. Once I got that done I was able to pry from the inside and get the shoes loose enough that the hammer worked to pop it loose. Liberal use of penetrating oil helped too. From my experience the drums can be very difficult to remove on a 924 under good conditions.
Its only money, you can always get more.
1979 924 N/A
1975 MGB
1991 Infiniti M30
1987 300ZX Turbo
Wobblydriver
PostPosted: Tue Jul 19, 2016 5:45 am    Post subject: Seized drums Reply with quote
Thanks. I'll spend a couple of days attacking it with penetrating oil and give it another try.
PostPosted: Tue Jul 19, 2016 11:09 am    Post subject: Reply with quote
Loosen the adjusters, remove inspection plugs on the back of the backing plates and pry the shoes away from the drums.
Tiny
PostPosted: Fri Jul 22, 2016 6:36 am    Post subject: Reply with quote
I was flummoxed with this once before, burning and bashing it repeatedly for a good afternoon until I realised and completely backed off the adjusters. Hey Presto. Drum fell off.
*****1981 - 924 - Auto - London, UK******
