Kenodog
Joined: 25 Jun 2003 Posts: 2645 Location: Vancouver,B.C.
Posted: Fri May 20, 2016 1:19 am Post subject: Sound dampner ? |
So I finally got the interior out of my car, all 100 lbs. of 35 year old carpet and insulation pieces. My plan for the car is to keep it to a bare minimum weight wise so I don't want to replace the old heavy pads with new heavy pads. So my question is what is the lightest weight sound dampener on the market ?
I do have a brand new German carpet set ,so that will be going in but what to put under that to keep *some of the road noise down ?
1981 931, Sabine
1991 Ford Ranger XLT 4x4
1996 Ford E-350 ex-FedEx Van
2014 Mazda CX-5 (Kinderwagon)
2019 KTM 790 Adventure
2024 KLX300
2024 KLX140
Kenodog
Posted: Fri May 20, 2016 4:59 am Post subject: |
Excellente !
1981 931, Sabine
2024 KLX300
2024 KLX140 |
snakoil
Joined: 09 Feb 2010 Posts: 362 Location: Montreal, Canada
Posted: Fri May 20, 2016 9:50 pm Post subject: |
I actually bought a bit of that stuff and used it on the 924.
Like you I teared down all previous sounds deadening.
I had simply put at the beginning "under carpet" with moisture film for heat and water protection that looked very similar to what was there before.
I had some water leak in my passenger footwell and decided to remove it and put the lobucrod in it's place.
This stuff is a lot lighter than my previous carped underpad and is quite easy to trim and glue in place.
I don't know about the heat portion of it but I can tell you I saw a difference in sound right away!
Also note that I had put liquid sound deadening on all my floor when I gutted it. unless technology changed majorly in the last 4 years I would not do it again and rather simply glue this lobucrod all over the place. _________________ 1979 924 NA |
