#25: 1978 Porsche 924 Limited Edition
PostPosted: Thu Jan 14, 2016 10:54 am    Post subject: #25: 1978 Porsche 924 Limited Edition Reply with quote
My US "Specials" collection is now complete. Just got home from retrieving this '78 LE from Olin IA.
  • Less than 23K original miles on the clock.
  • Yes, it's a slushbox, but I figured I needed to have at least one in the collection, so why not this nicely maintained low-mileage example?!
  • Brakes are soft, will need some attention.
  • Original wheels were replaced long ago by these Carroll Shelby specials.
  • Pasha interior has a few split seams, but is serviceable until I get around to redoing the inserts.
  • Original paint
  • Original factory-applied pinstriping
  • Original foglamps
  • Original leather-wrapped 2-spoke steering wheel
  • Few dings here and there, but I think most or all of them can be serviced by a paintless ding repair specialist
  • Overall in excellent mechanical condition, everything works except the AC
There were apparently 1800 of these made worldwide, which means there should be more of these than any of the other specials except the Martini. But this is only the 4th one I've seen in the past 5 years of searching.
On with the pix:
brian19600
PostPosted: Thu Jan 14, 2016 1:00 pm    Post subject: Reply with quote
Very nice! How is the automatic to drive?
gerben1986
PostPosted: Thu Jan 14, 2016 4:51 pm    Post subject: Reply with quote
What's special about this 'special'?
And that the chairs are broken, altough there are only 23k miles made with it...
911SC - 1980
PostPosted: Thu Jan 14, 2016 5:12 pm    Post subject: Reply with quote
When you say 1800 worldwide, do you mean USA?
PostPosted: Fri Jan 15, 2016 12:19 am    Post subject: Reply with quote
Technically, not much. It is a typical Porsche limited or special edition in that it is almost exclusively an appearance package. Like the Martini and Sebring, there's nothing remarkable about the engine. The only performance mod was the standard package that included the sway bars. Everything else is essentially cosmetic.
That said, what makes it "special" is that it is one of four "special editions" acknowledged by Porsche in the form of exclusive advertising pieces. For me, having the Martini, Sebring, and Weissach already, it only made sense to complete the quartet by seeking out a decent example of the '78 Limited Edition.
By "broken", I assume you are referring to the split seams. The suede fabric used for these style of seats is notoriously delicate. There is virtually no wear on the suede itself. The split seams are purely due to the age of the material (38 years old now!), not due to "seat time". In fact, aside from the seam split along the bolster, the driver seat is actually in better shape than the passenger seat in this one.
The standard Limited Edition package included the following:
  • Dolomite Grey Metallic paint
  • Factory applied white-over-black pinstriping
  • Introduction of the standard 8-spoke pressure cast alloy wheels
  • Front and rear stabilizer bars
  • Fog lights
  • Leatherette with Pasha cloth inserts on the front and rear seats
  • Leather wrapped two-spoke steering wheel
  • Leather shift boot on the manual (standard)
  • Stereo speakers in the rear
  • Manual antenna
Options available included:
  • Removable top
  • Automatic transmission
  • Tinted windows
  • Air conditioner
  • Power windows
What I like about this example is that it is essentially a "fully-loaded" / fully-optioned example, including the automatic; except that it is (oddly) lacking the power windows. But it has the auto, tinted windows, A/C, and sunroof.
PostPosted: Fri Jan 15, 2016 12:23 am    Post subject: Reply with quote
You are correct, these were apparently a US-only model. I missed that detail earlier.
I didn't drive it far, just around the block, because the brakes were really spongy, and it wasn't safe to do much more than take it around the block. Initial impression is that the engine is quite solid, runs very smooth, heats up and stays steady at the 1-tick mark. It was not nearly the dog I thought it would be, although my opinion may change once I get to really take it out in the spring. It was, however, a very weird sensation to sit down in the driver seat and not have a clutch pedal!
For now, I am planning to keep it original and leave the automatic in. Converting to a manual would not be difficult, and can be done "non-destructively", so that's always an option for the future. For this car, however, it is really a collector piece for me, and I will probably just take it out from time to time to enjoy it exactly as it is. I have plenty of other modified cars to thrash on the backroads!
PostPosted: Fri Jan 15, 2016 2:01 am    Post subject: Reply with quote
nice car. good pick i'd say.
Defender405
PostPosted: Fri Jan 15, 2016 4:55 am    Post subject: Reply with quote
Dammit, stop buying all of the nice cars left in Iowa. Now I'm going to need to go poach some other state if I want a special edition car.
That looks like a nice little car, I don't even mind that it's an automatic. Some times you just want to take an easy drive and not worry about shifting, it's good to have a car for each mood.
Its only money, you can always get more.
1979 924 N/A
1975 MGB
1991 Infiniti M30
1987 300ZX Turbo
PostPosted: Fri Jan 15, 2016 5:41 am    Post subject: Reply with quote
Try being in Michigan!!
Nice car Dan, great color and PASHA but I'd ditch the wheels and the bra..
PostPosted: Fri Jan 15, 2016 5:58 am    Post subject: Reply with quote
Agree 100%! I will be getting a set of the standard alloy wheels it came with for sure.
PostPosted: Fri Jan 15, 2016 6:02 am    Post subject: Reply with quote
Hmmm...this is the first IA car I've purchased. Here's the rundown:
MI: 9
WI: 3
FL: 2
OH: 2
IN: 2
CA, ID, PA, SC, IL, MO, and IA: 1 each
Full story.
Munky
PostPosted: Tue Jan 19, 2016 7:30 am    Post subject: Reply with quote
I'm in lurve with that Pasha interior!
+1 on the wheels and bra delete - otherwise, very nice car.
