gabo931
Posted: Tue Jan 05, 2016 8:48 am Post subject: 1980 931 EFI MicroSquirt |
Since I bought the car, I started gathering all the parts needed for EFI.
Now the intake manifold is almost completed. I showed the design of Ideolas intake manifold to a friend, and he started building it based on that design.
When test fitted, the only thing on the way was the coolant reservoir. I just need to relocate it and then it will fit perfectly
It clears the alternator
Ford 5.4L TB (75mm)
 _________________ 1980 931 M471 LSD |
Posted: Tue Jan 05, 2016 4:39 pm Post subject: |
looks quite nice. if i ever hack a turbo manifold thats how i'm going to make it look. _________________ Supercharger and EFI kits
https://www.the924.com |
Posted: Sat Jan 09, 2016 1:59 am Post subject: |
You can also swap over to the 944 style coolant reservoir, which is superior as it has a true pressure relief cap, less likely to swell and burst, and fastens more securely to the fender than the OEM 931 unit. _________________ erstwhile owner of just about every 924 variant ever made |
gabo931
Posted: Tue Mar 01, 2016 2:15 am Post subject: |
| morghen wrote: | | looks quite nice. if i ever hack a turbo manifold thats how i'm going to make it look. |
Thanks! This was the easiest yet functional way to go! The intake manifold design form Ideola was a big help!
I will keep you guys posted when all the parts are done and the car is running. _________________ 1980 931 M471 LSD |
gabo931
Posted: Tue Mar 01, 2016 2:19 am Post subject: |
| ideola wrote: | | You can also swap over to the 944 style coolant reservoir, which is superior as it has a true pressure relief cap, less likely to swell and burst, and fastens more securely to the fender than the OEM 931 unit. |
Thanks for the help! The reservoir was starting to break so im going to definitely get a 944 style. _________________ 1980 931 M471 LSD |
gabo931
Posted: Sun Mar 13, 2016 10:10 pm Post subject: |
Small updates on the project.
I decided to tackle down the turbo rebuild myself. It was really straightforward, and the instructions by forum member bnoon were very useful. The turbo is a series 1 6407. I also had 81 6022 but decided to go with the series 1.
6022
6407
Everything organized
New vs Old journal bearing
WEASEL149
Joined: 19 Aug 2005 Posts: 595 Location: UK, Sheffield
Posted: Fri Mar 18, 2016 4:53 am Post subject: |
Missed your thread but now subscribed - nice work!  _________________ 1979 UK 932 |
gabo931
Posted: Fri Mar 18, 2016 12:32 pm Post subject: |
| WEASEL149 wrote: | Missed your thread but now subscribed - nice work!  |
Thanks!! I will keep you guys posted with every update! _________________ 1980 931 M471 LSD |
gabo931
Posted: Fri Mar 18, 2016 11:13 pm Post subject: |
Tank alternative - Scirocco unit is far more robust than the 931 piece, drops in, and costs less than $20. _________________ Toofah King Bad
muffin787
Posted: Tue May 24, 2016 4:23 pm Post subject: Buen proyecto |
Exito!!! _________________ Porsche 924 1980, 944 brakes, GM alternator, GM Master Cylinder, 40decoe weber, Crane ignition module. |
gabo931
Posted: Wed May 25, 2016 5:22 am Post subject: Re: Buen proyecto |
| muffin787 wrote: | | Exito!!! |
Muchas gracias!! Igual a usted, espero ver su carro corriendo pronto! _________________ 1980 931 M471 LSD |
gabo931
Posted: Tue Jun 07, 2016 8:53 am Post subject: |
UPDATE
Testing the new parts out on the 931 head I use for measuring.
Will use a Mitsubishi evo 9 intercooler
Next step, start wiring the computer and all the sensors needed for EFI.  _________________ 1980 931 M471 LSD |
